		Chat Area => General Car Chat => Topic started by: bestie26 on 10 July 2011, 22:54:17
				wasnt sure where to put this post as its not an omega help request.
 does anyone know how to get my central locking working again on from they keyfob on a 2002 vectra c
 i have had to change the passenger door due to a incident with a bollard the door locks on key fob just wont unlock?
 is there a way of re=programming the key ?
 cheers guys
				This should help.... you need page 54
 http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf
				Is it just that door thats not lokking/unlocking? If so, is the PDM plugged in correctly (does the leccy window work)? AFAIK, the PDM doesn't need to be coded to the car, although you could swap them over anyway.
				Major probs this morn came out and door wouldnt open at all i could physically lift the lock pin up and down and the handle inside and out was visable pulling the cable it just wouldnt open managed to get the door open after breaking the black plastic cover around the latch lock area and flicked a leaver and it opened? ive now put my old door back on and it locks unlocks and opens perfect.
 really stuck now as ive been offered 2x doors and a wing in the right colour cheap which will eliminate all the scratches and the scrape from bollard but i darednt put them on incase they too stick thereselves shut ! please help before i go insane ;)
				sorry answer to above is yes window was working fine dont know if it was just a duff door or what. did open and close fine when fitted just didnt unlock on key manually or via keyfob
 cheers
