Chat Area => General Discussion Area => Topic started by: Tafty on 29 July 2007, 14:52:01
Title: Supercharger - what do you lot think?
Post by: Tafty on 29 July 2007, 14:52:01
http://cgi.ebay.co.uk/Electric-Supercharger-Turbo-Vauxhall-Vectra-SRI-GSI-V6_W0QQitemZ220134770151QQihZ012QQcategoryZ36680QQrdZ1QQcmdZViewItem
Debating with my mate the pitfalls and potential money rip off these may have - any more knowledgeable people give a helping hand before I throw my money away :o
Title: Re: Supercharger - what do you lot think?
Post by: Kevin Wood on 29 July 2007, 15:14:09
A total waste of money. Bolting a hardryer onto your intake will only restrict the airflow if anything.
For a supercharger to make a decent power hike it needs to generate a significant amount of pressure at the flow rate the engine is demanding at maximum output. This means it needs to be powerful. In some cases 1/3 or more of the engine output is being used just to feed the supercharger. A little fan that looks like it's come off the CPU of a PC will not make the slightest difference and, as I way, will probably just restrict the air intake.
Post by: Tafty on 29 July 2007, 15:16:00
Cheers Kevin - just the words of wisdom I was after - top man  - thanks :y
Post by: Tony H on 29 July 2007, 16:25:27
If you read the terms and conditions of the guaranty it states you can have a full refund if you are not satisfied providing you return it unused and in its original packaging HOW THE FU*K DO YOU KNOW IF ITS ANY GOOD IF YOU DONT TRY IT :-? If the company had faith in its product it would offer an unconditional guaranty cos if it did what it said on the tin no one would want a refund
Post by: familyman on 29 July 2007, 19:54:14
Sounds to me like at best it'll cool the intake air temp fooling the system into thinkinhg its colder than it really is so richen the mixture. I believe there is a £5 ish resistor that'll do the same to your Intake air temp sensor. I can't beleive it would sufficiently increase air pressure above atmospheric to make a difference
Unless you've money to waste i would be very doubtful
Post by: Chopsdad on 29 July 2007, 19:57:20
But it would be good to tell your mates you have a Supercharged V6 - even if it doesn't work  :D
Post by: Tony H on 29 July 2007, 21:03:27
[/highlight]
As said if you want to do that stuff a hair dryer up the air intake :D ;D
