Trading Area => Car Parts, bits For Sale & Wanted => Topic started by: joshwyatt on 02 January 2010, 19:08:07
As title really, a known good one is wanted, also reffered to as dis pack I believe. For the 2-4-6 bank (N/S)
Hi,
Are you after second hand coil pack.
Either new or used...I don't mind. However, if used it must be known to be in good working condition
I have done a rocker cover gasket change and bits, so have replaced both coil packs, they are working but do not have the rubber covers for the spark plugs
That'll do nicely :y
Make sure it's the same part number - there are three different ones to pick from! ;)
What, for a DBW Y26?
Only one CPP pack that I know of?
I suspect you're thinking of the earlier DIS / non DBW engines? :)
According to my EPC Y26SE only has 2 options ... and that's left or right .. :)
26 MODULE, IGNITION CONTROL UNIT FOR CYLINDER NOS. 1, 3, 5 (BOSCH 0221503026) 9118114
26 MODULE, IGNITION CONTROL UNIT FOR CYLINDER NOS. 2, 4, 6 (BOSCH 0221503027) 9118115
(http://img689.imageshack.us/img689/7309/coil.png)
My understanding too - thanks for checking kind sir :y
I can confirm - 9118115 as I've just got one for my Y26SE :y
You're Welcome young man .. :)
Many thanks all!
Paul D, I'd like very much to take you up on your offer :y
How much do you want for it?
whats the symptons Josh, tried new plugs first?
Yep - it's defo the coil pack ;)
I had that messing about with the wife's Elite (2.5), and didn't know the later engines were different!
Aah well, every day's a school day! ;D
Coolio, missed the thread on diagnosis! ::)
If it was your personal car i would say avoid second hand and buy new, but as this is a fixer-seller project, second hand will be fine :y
;D there was no thread...you're not losing your mind. James came round and did an excellent job on the cambelt change and service jobs. However there was a missfire, we swapped a coil pack on the 1-3-5 bank from another Omega and still the same, new plugs had just gone it...so hence it must be 2-4-6
Are you still planning on going to the scrappy at bloxham sometime? If so, let me know when and I'll join you :y
Yeah think so, need to fix my washer jets first >:(
