Trading Area => Car Parts, bits For Sale & Wanted => Topic started by: Entwood on 21 June 2010, 22:21:16
Title: Wanted - reversing sensors
Post by: Entwood on 21 June 2010, 22:21:16
Wanted for facelift elite, 2 x factory fitted "park pilot" reversing sensors and the corresponding bit they fit into !! This is made up of 2 sections.... one bit clips into the hole and its surround in the bumper, the lugs appear to be extremely fragile ....  :(  the other bit clicks inwards step-by-step to enable the sensor to be accurately aligned.
If anyone is breaking one with park pilot and doesn't want to split the thing up .. I might still be interested in the whole caboodle...  sensors/mounts/control box ... if the price is right ..   :)
Title: Re: Wanted - reversing sensors
Post by: HNO3GOH on 21 June 2010, 22:29:32
I have the 4 sensor's from my 03 omega rear bumper, gen fit in 157 star silver but they are only the sensor's.
Post by: Dany on 21 June 2010, 22:30:05
I'm after a complete one too  :)
Post by: Entwood on 21 June 2010, 23:23:31
Can I put you on hold with them ??? I might end up buying them off you and trying to "fix" the mounting bits if no-one has any .. or asking AndyC if the mounting bits are available ..
Post by: HNO3GOH on 23 June 2010, 18:42:06
Thats fine, just give me a shout if you need them :y
Post by: Entwood on 23 June 2010, 22:34:33
Thanks .. I've sent andyc a PM about the mounting brackets .. awaiting an answer .. :)
Post by: VXL V6 on 23 June 2010, 23:05:56
Well if Entwood only wants two units off you (and due to the fact they are already sprayed Z157) then i'll take the other two as spares for the future!
Just chuck them on my pile of bits I have still got to collect from you!  ::) ;D
Post by: Entwood on 07 July 2010, 10:43:35
Still after 2 of these ... Not sure what happened to HN03GOH's offer.. its all gone quiet on the PM front .. :(
So if anyone has 2 reversing sensors ....  :)
If not its a large number of pennies to andy @ drive .. :(
Post by: Marks DTM Calib on 07 July 2010, 15:54:09
One sensor here:
http://www.carpartsconnexion.com/vauxhall/partdetail.asp?dp=70988&f=Vauxhall&m=Any+model&y=Any+year&cat=0&pn=90513512&p=1&
I seem to recall that the fittings are available on their own
Post by: Entwood on 07 July 2010, 16:19:12
One sensor here:
Thanks .. contacted them to ask how many they have ... :)
I got a set of fittings from AndyC ... :)
Two of the sensors fail to "tick / vibrate" so my guess is they have had it .. :(
One question you might know .. if you disconnect a faulty sensor does the "error" beep stop ?? or does it continue as the circuit is now "open" ???
Post by: feeutfo on 07 July 2010, 16:38:46
One sensor here:
All sensors must complete a circuit to silence the tone. Swap a good ticking sensor into a bad sensor position. If the good sensor then does not work you know it's a wiring or connection issue, if the good sensor works leave it there and plug the non ticking sensor into the good sensor position if it still don't work it's fubar.
Any thoughts on how these behave when towing/reversing?  :-/
Edit to add, issue with mine was purely a poor conections in the plug to sensor. Swapped it with the one "next door" and all is well. :y
Post by: Entwood on 07 July 2010, 17:41:23
Thanks for that .. swapping the sensors is a bitch of a job due to the Irmscher rear bumper .. makes it very difficult to get your hands on the sensors... I'm actually planning to take the bumper of to change the two duff ones when I get replacements !! (looks like I have 1 new one on its way) .. probably have to pay AndyC full wack for another .. :(  )
As to towing/reversing, there is "supposed" to be a way of "telling" the system you are towing via a feed through the towing electrics, bit like the system that turns off the high intensity fog lights, but I haven't sussed it yet ... so I just get got the noise when reversing with the van on ... at present the speaker is unplugged as all I get is the error tone in reverse !!!
Post by: feeutfo on 07 July 2010, 18:25:52
If it helps, I didn't undo the bottom of my irmscher, just the wheel arch screws and the 4 behind the oval caps where the boot shuts, tape up the wing sides to prevent scratches and gently lean the bumper back enough to get your hands in from the top. May need to support bumper from the bottom with a bear crate or something of suitable hight. The sensor wires aren't long enough to do much else ime.  >:(
Post by: Entwood on 07 July 2010, 22:23:52
Thanks for that .. hadn't considered that idea ... 'twas gona undo the lot and lie the bumper backwards/horizontal on supports while I messed with the sensors ..   your way might be easier .. :)
Post by: Entwood on 09 July 2010, 12:23:07
One sensor here:
:(  'Twas the wrong sort ...  even though the guy insisted it was the correct one .. so I still need 2 but have a brand new Bosch sensor 90513512 .. apparantly I need the "special vehicle" parts .. which I have now ordered from AndyC .. at £30 odd + VAT each .. :(
So if anyone is after the "other" sort -- round and blue as against black and squareish ... let me know  :(
Post by: Marks DTM Calib on 09 July 2010, 13:58:38
Got any part numbers?
Post by: Entwood on 09 July 2010, 20:37:08
The one I have .. that doesn't fit ...  90513512
The ones AndyC has ordered for me ... don't know ..but the car is listed as SVO so he's ordered from that .. seems to know what he's on about !!!
Post by: biggriffin on 11 July 2010, 22:32:36
when im reversing in my artic i use the mirrors to see what im about to reverse into or get out and look first ;D
Post by: Entwood on 11 July 2010, 23:20:42
Agreed .. A non-essential driving aid ... however .. I have this thing that if it is fitted to the car it should be working properly... which is why the powersounder was replaced and the reversing sensors will be sorted.
At present I have a hole where one should be ... and it is NOT staying like that !
OK .. I could stick a failed one, leave the speaker unplugged,  and no-one would know ... except me.... but it would not be "right"
Post by: feeutfo on 11 July 2010, 23:59:30
Absalutely right, all is Mr vauxhall intended. He knows best ya know.....well, sometimes. ;D
Is it worth trying that breaker near Heathrow?
Post by: Entwood on 12 July 2010, 09:15:40
Thanks for the thought Chris ... but it's all far too difficult !!!
Seems my vehicle is "Special Order" according to AndyC and his computer - I think this is the full Irmscher kit as "factory fit" .. and I have different sensors to the normal ones. Mine are sort of rectangular with rounded corners and 3 pin socket, "normal" ones are round with a 4 pin socket.
Whenever you speak to anyone - except AndyC - they are adamant that the round ones are the only ones .. so I get the wrong parts. Have bitten the bullet and ordered new ones from AndyC.
Post by: Andy B on 12 July 2010, 09:33:10
.... Have bitten the bullet and ordered new ones from AndyC.
at least you now know you're going to get the correct bits!  :y  :y  :y
Post by: Entwood on 12 July 2010, 09:53:53
I'm ever hopeful .....   ;D ;D ;D ;D ;D
Post by: feeutfo on 12 July 2010, 19:44:08
Ah, interesting. Plus paint?
Post by: Entwood on 13 July 2010, 12:13:16
AndyC strikes again ... parts just been delivered .. and they look EXACTLY like the one I've taken off ... (except for the paint .. which is on order from local dealers )...
Just need it to stop raining so I can drop the rear bumper to fit them next, although I might go and plug them in just to see what happens .......  :)
many thanks Andy .. prompt service appreciated ... again ..  :y :y :y :y
Post by: Andy B on 13 July 2010, 12:29:28
AndyC strikes again ...  ......
I feel that the north is missing out on not having our own andyc, maybe we should campaign GM in having more properly trained up!  ;) ;) ;)
