Trading Area => Car Parts, bits For Sale & Wanted => Topic started by: unlucky mark mv6 on 07 November 2010, 20:35:27
As above,let me know what you got,along with price.List of requirements as follows,thanks to the guide from matchless. :y
R28 gearbox with rear crossmember and exhaust support
Diff
Front prop section with vibration damper
clutch cover and driven plate
flywheel and bolts
Clutch master cylinder and clutch pedal assembly
Plastic clip securing clutch pipe union to bulkhead
Brake pedal
Gearlever assembly
Piece of plastic behind gear lever
Clutch pedal switch
Section of gearbox/lamba sensor wiring loom. :y
DiffFront prop section with vibration damper
flywheel and bolts
Brake pedal
Gearlever assembly
Clutch pedal switch
your diff is 3.9 where same fitted to cars with manual box
your best bet and cheapest is to buy a cheap 3.0 elite and break it for the bits you need. by the time you source all the bits and add on postage it will cost you double. 8-)
flywheel and bolts
Brake pedal
Gearlever assembly
Clutch pedal switch
Is that correct serek,if so it will save a bit of hassle and money. :y
don't forget brake pedal
Automatic 3.2 should have a 3.90 diff fitted. This gives 26 MPH/1K RPM. The same diff with a manual box would give shorter gearing. About 22 MPH/1K RPM according to this:
(http://images.omegaowners.com/images/techinfo/omega_gearratios/gearratiosbv9.jpg)
If you want to maintain the original gearing a 3.70 diff might be a better match. I think this is what the 3.0 Manual had.
It is geared a little long for my liking in auto form, so might be worth trying with the 3.90 diff first?
Automatic 3.2 should have a 3.90 diff fitted. This gives 26 MPH/1K RPM. The same diff with a manual box would give shorter gearing. About 22 MPH/1K RPM according to this: ......
I wonder what gave a Senator 29mph / 1000rpm considering they both used an AR35 gearbox :-/
senator got 3.7 diff not 3.9 like omega
Mark, have you seen this on ebay?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160501761484&ssPageName=STRK:MEWAX:IT
Not my car, nor do I know the seller...but it seems the best option, buy the complete vehicle take the parts you need and break the rest, or put the auto stuff into it and sell it on afterwards.
plus got R30 gearbox and LSD :y
Looks a cracking bargain for someone josh,but unfortunatly i cant go down that route,as i have nowhere to keep the car anyway,plus dident fancy the extra messing about,especially in the cold weather. ::) :y
Just out of curisity,which parts from the list can i take off another manual model,for instance 2.0 or do they all need to be from a 3.0. :)
Pedal box
Gear selector
Clutch pipe clip
These all are the same on all models :y
I've actuaqlly been running a 3.0 MV6 on trackdays for the past four years with a 2.0 gearbox in it.
Pedal box
Gear selector
Clutch pipe clip
Just as i thought lee,just needed it confirming. :y,fancy a trip to the scrappy the weekend mate. :D
Surely someone has some spare bits for this conversion. :-/
I can have most parts of your list but this weekend I got lots to do but next saturday I can go to my local scrap yard and take some parts,
last saturady I saw there 2.5 manual.
last time when I bought conversion kit cost me round 100£
