Trading Area => Car Parts, bits For Sale & Wanted => Topic started by: RobG on 14 March 2011, 20:32:56
Title: H/Light washer pump wanted
Post by: RobG on 14 March 2011, 20:32:56
As title. Need it for a facelift but I assume they`re the same across the range :-/
Title: Re: H/Light washer pump wanted
Post by: MutantCav on 15 March 2011, 09:26:00
If they are the same I have one here mate :y
Post by: RobG on 15 March 2011, 09:54:36
Can you post up the part number Chris and I`ll check mine :y
Post by: fiend61 on 15 March 2011, 12:03:52
got a question about this  ;)
do you get another pump if retro fitting headlight washers ?
its just that i have seen pumps with two outlets  :-/
could these be used in the original tank (replacing the single outlet pump)  to do windscreen and headlights?
Post by: RobG on 15 March 2011, 12:05:59
Twin outlet is for estate I think. Pipe bore for H/L washers on the Mig is about twice the diameter of the screenwash pipe
Post by: fiend61 on 15 March 2011, 12:11:31
ahhh i see (said the blind man)
cheers rob  :y
Post by: Elite Pete on 15 March 2011, 13:06:31
Because of the amount of water the headlight washers use, the tanks a lot bigger as well (but still not big enough) ::)
Post by: albitz on 15 March 2011, 15:29:01
Of course the superior Senator also had wipers on the headlamps, so didnt need gallons of water to blast a bit of dirt off. ;) :)
