Trading Area => Car Parts, bits For Sale & Wanted => Topic started by: SJKOO01 on 12 August 2011, 19:06:35
Title: WANTED please - Battery securing bolt & bracket
Post by: SJKOO01 on 12 August 2011, 19:06:35
Are there any breakers on here that happen to have going spare, a good condition battery securing bolt and the battery securing bracket itself please.
Found out from the Mot that the bolt has snapped, so nothing holding battery on, manage to get it through with a rachet strap of all things!
If you can let me know how much you want + post - Thanks.
Cheers.
Title: Re: WANTED please - Battery securing bolt & bracket
Post by: RobG on 12 August 2011, 19:09:06
Have you managed to remove the busted bolt from the captive nut?
Post by: SJKOO01 on 12 August 2011, 19:18:33
No not yet Rob.
Was going to drill through and then re-tap hole / captive nut if I can.
Not easy though as there is still a lot of bolt in the bottom of the nut and not easy to remove unfortunately  :-/
Post by: RobG on 12 August 2011, 19:24:40
Same happened on mine. Drilled bolt out and used a bog standard nut & bolt. If you can`t get bolt out can`t you just drill another hole a few mm away and use that. Got a fairly new bracket you can have buckshee if you want
Post by: SJKOO01 on 12 August 2011, 19:33:27
Would appreciate having the bracket please, let me know how much postage and for the bracket - Cheers  :y
Post by: RobG on 12 August 2011, 19:37:35
Buckshee means sod all, nowt, zilch. PM your addy and I`ll stick it in the post
Post by: SJKOO01 on 12 August 2011, 19:40:50
Never heard of that before  :-?.
Cheers  :y
Post by: RobG on 12 August 2011, 19:41:57
Cheers  :y
Sheltered life ;D ;D
Post by: SJKOO01 on 12 August 2011, 19:47:15
Cheers  :y
Yes  ::)
Been in a nice warm room that the Health and Safety bunch would be proud of, along with a really good jacket with extra long arms which always made me feel warm... mind you, always thought the fasterns were in a strange place  ::)  ;D :P
Post by: twiglet on 12 August 2011, 21:38:14
Rob, I like your style!  :y Man after my own heart.  8-)
Post by: zirk on 13 August 2011, 19:29:27
I thought Buckshee was illegal in the West Counties, or am I thinking of Muffin the Mule.  :-/
Post by: RobG on 13 August 2011, 19:34:30
http://www.collinslanguage.com/results.aspx?context=3&reversed=False&action=define&homonym=0&text=buckshee
