Chat Area => General Discussion Area => Topic started by: tunnie on 14 August 2007, 20:23:16
Title: Project D - Oil Cooler
Post by: tunnie on 14 August 2007, 20:23:16
Decided to call the Elite LPG Facelift project D,
Project A - 1998 Relfection V6
B - That shed of an Elite Estate
C - Senator
Now the car ran a little hot on the way back, 92 all the way......
I am 99.999999% sure its the oil cooler nackered:
(http://www.tunnie.co.uk/omegaforum/projectd/oilcooler/DSC07535.JPG)
(http://www.tunnie.co.uk/omegaforum/projectd/oilcooler/DSC07536.JPG)
(http://www.tunnie.co.uk/omegaforum/projectd/oilcooler/DSC07537.JPG)
Title: Re: Project D - Oil Cooler
Post by: TheBoy on 14 August 2007, 20:24:59
As I said Sunday, I am sure the oil cooler has gone (unless previous owner had recently changed but not had time to do more flushes?)
Post by: tunnie on 14 August 2007, 20:26:04
I think there is too much there for that, I remember after yours was done, there was oil in there, but specs, not half a oil tanker!
Post by: TheBoy on 14 August 2007, 20:30:06
Oh the first couple of flushes there was lots of oil. Double check with previous owner ;)
Post by: tunnie on 14 August 2007, 21:20:12
Err I did, he never touched it.  :(
Post by: TheBoy on 14 August 2007, 21:33:07
Ah...  ...OK, defo needs doing.  But you've helped do one before, so you'll have no probs - take your time, don't rush, and give it plenty of time to seal.  If stat is weeping, reseal that as well.  Remove all rubber coolant pipes and flush them through thoroughly. Same with rad. Same with waterpump and block.  Possible you may have to replace waterpump seal, but I would try to delay that until changing cambelt and waterpump (ie after a few good flushes)
My top tips, from bitter experience...
1) Do NOT bend the oil pipes!
2) Do NOT shear the banjo bolts ;D
Post by: tunnie on 14 August 2007, 21:38:31
What t!t did that?  ::)
To flush the block, just run the hose though the oil cooler slot once removed?
Post by: tunnie on 14 August 2007, 21:40:59
what was the deal with those banjo bolts?
They did not come with your kit? Did you get a part number for those? - I seam to remember they were supposed to be replaced
Post by: TheBoy on 14 August 2007, 21:42:53
Try to scoop out as much as poss from all orifaces.
Also, ensure the mating surfaces for new oil cooler plate are spotlessly clean, and very dry.
Post by: Markie on 14 August 2007, 22:51:33
oil cooler for cert, dont bend the pipes, get new banjo bolts, dont reuse them they will shear...and torque everything as the bok says...
oooh and avoid Passats  8-)
Post by: Markie on 14 August 2007, 22:53:35
,.....and have you got a decent torque wrwnch yet as the one you listed earlier is too "heavy" an doesnt give the low down settings you need for such a job... :-/
Post by: tunnie on 15 August 2007, 06:31:46
no i need to buy one! - i might be going via halfrauds on the way back tonight. I would like to get the cooler done on Sunday....
Just checked, and Halfords have 2 wrenchs that look the same just higher and lower values:
this one does 8-60Nm
http://www.halfords.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10151&productId=178843&categoryId=31482
Here it lists all of them, think i will go for the top one and bottom one:
http://www.halfords.com/webapp/wcs/stores/servlet/BasicCatalogSearchResultView?searchTerm=Torque+Wrench&storeId=10001&catalogId=10151&langId=-1&pageSize=10000&beginIndex=0&beginIndexForPagination=0&sType=SimpleSearch&searchType=EXACT&searchTermCaseSensitive=no&searchTermOperator=LIKE&searchTermScope=3&coSearchSkuEnabled=true&resultCatEntryType=2&sortOrder=ascending&resultType=2&topCategoryId=ALL&x=590&y=104
Post by: Taxi_Driver on 15 August 2007, 07:55:09
Why is it all the halfords links you post Tunnie......i always get IE carnt display the page  :(
I got the 8-60nm one btw  :y covered in free protection oil/grease  ;D
Post by: tunnie on 15 August 2007, 09:17:29
cause the halfrauds website sucks!!
Plan to call buy tonight and pick up two torque wrenches, the lower and higher ones...
I posted in the other thread, that tool to remove the oil cooler pipes near the oil filter is called the "Crows Foot?"
Is that what it will be labled as  :-/
Post by: Markie on 15 August 2007, 09:26:26
should be - crows foot spanner, 19mm required for the job, you may not get them in Halfords
best way of describing them would be shaped like a 50p with the top taken off you may not get them as a spanner but more as an adaptor that will go on your ratchet,,,like the ones i bought below....
http://cgi.ebay.co.uk/SEALEY-AK598-Crows-Foot-Wrench-Set-10pc-Metric_W0QQitemZ160124201801QQihZ006QQcategoryZ30917QQrdZ1QQssPageNameZWD1VQQcmdZViewItem#ebayphotohosting
Post by: tunnie on 15 August 2007, 11:44:25
Cheers Markie, just checked Machine Mart, nothing listed for Crow foot, i will either go to a machine mart here or Halfraunds tonight, i only have time to go to one or the other
