Newbie Area => Newbie Welcome Area => Topic started by: Peanuts on 15 October 2006, 09:05:50
Hi
I have a pre-facelift Omega 2.0, ( only had it two months ), if I travel 12 mile round trip, then turn off the engine, it wont re-start, I get all lights on dash, and a click from around ( it seems ) the gearlever area, is there a starter relay anywhere that could be at fault. your help would be appreciated.
ps have fitted a new battery
Regards
Peanuts
Welcome Peanuts. :y
if you post your problem in the help section you will probably get a quicker response, although I'm not sure you will get anything today as a lot of the boys are at Santa Pod.
Hi Ross
Thanks for the welcome.
I will post in the help section
Regards
Peanuts
Peanuts
welcome, as ross said - posting in the help section will get the input you need. Dont be put off today by slow response, as almost all members on here are at santa pod, and those that arent are meeting in stirling!!
Meantime - is it turning over, whats the milage, any recent work, does it eventually start - or only after cooling down.....im thinking sensor related but if you can provide some more info....
oh and finally you may want to look in the other areas on our forum, for the paperclip test - this is a test you can do that will flash u any issues your car has on your omega computer screen, it will also help us determine the fault.
All the best
mark
in fact dont go looking here is the paper clip test thread
http://www.omegaowners.com/forum/YaBB.pl?num=1152601768
and heres what the codes mean
http://www.omegaowners.com/forum/YaBB.pl?num=1160152415
let us know what you get....if anything ;)
Hello & welcome :)
Hi peanuts and welcome to the forum :y
Welcome to the forum :)
Apologies for the late welcome by anyone from Admin team, but we were otherwise engaged in drinking activities.... ;)
Welcome to the site :y
Hi Peanuts and welcome :y
To everyone
Thanks for the warm welcome. It nice to see their are still thoughtful and helpful humans out there. :)
I will try to take al advice onboard, as much as I am able, but the old bones arn't what they used to be ;)
Thanks again.
Regards
Peanuts
Welcome to the site Peanuts :y
Hi Peanuts,and welcome
Hi
2.0 Ltr GLS Auto R Reg, Starts fine in the morning, 10 to 12 mile round trip, then nothing on arriveing back home, turn the key just a click, no dimming of head lights, dash lights stay bright, new battery fitted, I tried the old screw driver to the ear trick, on a part where there are four small bore pipes coming out, because when my son in-law turned the key the click seemed to come from this part, it is just below the battery, I know I am clutching at strews but help needed urgent, please, have not done anything to car only fitted battery supplied by vauxhall dealer.
Regards
Peanuts
Hi m8 and welcome to the forum :y
