Newbie Area => Newbie Welcome Area => Topic started by: steveo on 28 December 2007, 14:59:39
Hello Everyone,
Hope you all had a good xmas.
Mine was okay except I've snapped the cambelt on my Omega V6, :( what I'd like to know is whether the valves hitting the pistons on these engines is a guaranteed certanty or whether it's just a possibility. If it's only a possible then I'll have it looked at.
Anyone know of any independents in the West Wales / Carmarthenshire area who can do the belt / tensioners or is it best to take it to a main agent ? My local garage who does all my other servicing declined to do the belt because of the need for the specialist locking tool kit.
Sorry about all the questions in a newbie post.
Kind regards,
Steveo.
Hi Steveo and welcome to the forum :y
I would say if the belt has snapped then it will be replacement heads but if the belt has only jumped a couple of teeth then you could be lucky.
welcome mate, bad luck on the cambelt.
do you know when it was last changed?
Welcome to the forum :y
Hello & welcome :y
Welcome :y
The damage is a matter of chance..Depending on your speed and RPM..
Hello and Welcome
Sorry about the Cam belt, but on a lighter note HAPPY NEW YEAR
Very nice driving county :y :y :y again sorry about the cam belt
Welcome, hope you enjoy the forum. :)
Seasons greetings and welcome to the O O F :) :y
Welcome to the Forum :y
Welcome Steveo and enjoy :y
hiya steveo and welcome, pity about the belt. the damage is sometimes done not when the engine stops but when you try and restart......... :(
Welcome to the forum steveo, sorry to hear about the cam belt. Very few get away whithout damage to the heads and valves but you will need a compression test to know more, best of luck to you. :y
Welcome :)
3 teeth slip usually considered maximum before bent valves
Welcome to the forum. :)
Hello & Welcome :y
Hi,
welcome to the site.
Best of luck with the Engine.
Zirk.
Hello and welcome to the best Omega Forum on the Net :y
Thanks for all the encouragement and the tips. I'm still trying to find a garage that's brave enough to take it on. Guess it may have to be the main agent. There's not many V6 vauxhalls round here as far as I can tell and none of the local garages seem to have the alignment kit and are reluctant to buy it if they only ever use it on my car.
As for your questions well I as far as I can gather from the previous owner the belts were changed within the last couple of years, but I have that sort of feeling the it was just the belts not the tensioners as well, and as I'd originally only bought the car as a stop gap I didn't think anymore of it.
Anyone got any ideas on how much I'd be looking at to spend on new heads if the valves are bent ? Or would a complete replacement engine from a breakers (if i can find one) be a better bet ?
Regards,
Steveo
You can do the job your self as it's not hard, just a bit fiddly in places but do able. if still unsure shout help real loud and there maybe a member who maybe able to assist you if not too far.
Hi and welcome, from one newbie to another. Loads of useful info and help on here.
:) Hiya and welcome.
