Newbie Area => Newbie Welcome Area => Topic started by: dodgyvinyl on 27 August 2008, 22:50:32
Hi.
I've been a Rover 800 owner for 15 years, now I need something with a bigger boot.
Just bought my first Omega.
It's a 2001 2.2 CDX auto estate, 60k, FSH and spotless. I paid £1450 which is probably towards top end but the leather had me hooked.
Initial drive home from the auctions and I'm very pleased. It's quiet, smooth and comfortable, if a little underpowered.
The only slight niggle on the car is that the drivers door lock doesnt work off the remote, although all others do.
Is this common and worth me exploring fixing myself?
Any other things I should look for as potential problems with the Omega?
Thanks in advance, I look forward to learning quickly and contributing here.
Carl
Hello Carl and a warm welcome to you! :y
Hi, welcome to the forum. :y
Hi Carl and welcome to the forum ;)
The door is easy enough to sort out, its probably the central locking actuator packed up, they can easily be picked up second hand, try sending a PM to one of the lads that break Omegas in the for sale section.
Alright mate welcome to the oof :y :y
Welcome to the OOF :y
Hi Carl Welcome to the OOF :y There's also a How2 on here that will show you how to change the door lock Motor
welcome to the oof mate. :y
Welcome Carl :y
"Hello" and Welcome :)
Hi and welcome to the site mate :y
Welcome to the forum :y
Hi Carl and welcome to OOF. :)
With a username like dodgyvinyl do I take it you're a DJ or ex-DJ?
Hello . :y
Hello and welcome
Door lock should be an easy fix ... mine was the same , think it was the motor :y
Hello carl and a warm welcome to OOF
Hello and welcome to OOF :y
Hello and welcome :y
Hi Carl. Welcome bod :y
Welcome Carl to OOF, enjoy the forum :)
Hi and welcome to the forum :y
Hi welcome to the forum. Please make sure that the cambelt has been done. If you have no definate proof of a kit being fitted get it done including water pump and auxilliary drive belt. This will give you peace of mind for the next 40,000 miles. Well worth it. Omegas are excellent cars if treated well.
Welcome to the forum :)
greetings! door lock might be solenoid. not a difficult job, can be tricky to get at cos of airbag in door, but reasonably cheap to fix with replacement from the for sale section of oof.
good luck with it! and welcome to oof!! :y
Hello & welcome :y
hi, welcome to oof :y
Hi Carl, welcome aboard mate :y
Welcome to the forum Carl...Fix it yourself you'll get all the help you need on here and you'll save a packet :y
Thanks for all the warm welcomes guys!
