Newbie Area => Newbie Welcome Area => Topic started by: Chris W on 27 September 2008, 20:51:15
Title: New member & thanks for excellent tech section
Post by: Chris W on 27 September 2008, 20:51:15
Hi all. Just joined a couple of hours ago and you have just saved me a lot of time and effort with my crank sensor change. I was about to remove the oil cooler pipes and exhaust down pipe to fit a new sensor. The tech section is fantastic. Job competed in 30min after reading tech help.
I have had my  Y reg 2.5CD estate(very last of the 2.5's) for 4 years. It only had 29k on it when I bought it and now has 70k. Had lots of problems. I do most of the work myself. Cam belt was a bit of a hold your breath moment when i first turned the key on a 40k engine. I had a burnt out clutch (my own fault) VX dealer advised new flywheel also reqired for a cool £900!!!! £25 scrap yard flywheel did the job. Despite the problems love the car. It carries 8x4 sheets of plasterboard when required and can  head to France each year with 3 kids and all the lugage and i can still see out the back.
Look forward to chating to other members.
all the best Chris
Title: Re: New member & thanks for excellent tech section
Post by: Lizzie_Zoom on 27 September 2008, 21:07:22
Hello Chris and a very warm welcome to you! :y :y
Post by: less on 27 September 2008, 21:08:20
Hi Chris, welcome aboard mate  :y
Post by: albitz on 27 September 2008, 21:15:24
Welcome to OOF Chris. - Did you route the sensor wire towards the inner wing and away from the exhaust manifold ? :y
Post by: Chris W on 27 September 2008, 21:22:28
Hi albitz. Yes i followed the instructions and routed the sensor wire towards the inner wing and away from the exhaust manifold. I had been under the car thinking that I would have had to reinstall as per factory which would have taken hours!
Chris
Post by: dieseldean on 27 September 2008, 21:24:40
welcome :y
Post by: TheBoy on 27 September 2008, 21:33:19
Welcome to the site :y
Post by: Mr Skrunts on 27 September 2008, 22:03:34
Hi, welcome to the site.   :y
Post by: JueV6 on 27 September 2008, 22:37:51
Welcome to OOf. chris :y :y
Post by: RobG on 27 September 2008, 22:43:42
Hi Chris, welcome to the forum :y
Post by: feeutfo on 27 September 2008, 23:22:43
hi Chris from er ... Chris.  ;)
Post by: waspy on 28 September 2008, 09:02:51
Morning Chris. Welcome along to the OOF  :y
Post by: HolyCount on 28 September 2008, 10:45:13
Hi Chris, welcome to the forum -- good to see it's working for you already  :y
Post by: The Red Baron on 28 September 2008, 11:07:53
welcome to the forum mate. :y
Post by: mars on 28 September 2008, 11:51:10
Hi Chris and welcome :y
Post by: zirk on 28 September 2008, 12:55:41
Hi and Welcome to OOF.
Post by: achoo81 on 28 September 2008, 20:34:41
Hi Chris, welcome to the forum.
Post by: jimmas on 28 September 2008, 22:23:26
Hello and welcome to the forum  :y
Post by: dbug on 28 September 2008, 23:12:05
Welcome to OOF  :y :y
Post by: Entwood on 28 September 2008, 23:29:47
"Hello" and Welcome :)
Post by: HGV mechanic on 29 September 2008, 10:34:01
wel done mate :y
Post by: puffa on 29 September 2008, 16:38:03
hi, welcome to the forum Chris :y
Post by: mv6copcar on 02 October 2008, 23:39:13
