Newbie Area => Newbie Welcome Area => Topic started by: Andy H on 27 July 2009, 22:26:15
Hi from a new member.
I bought my current Omega 6 years ago (at 134,000 miles). 200,000 miles should be reached in a week or so.
If I had discovered this bulletin board 6 years ago it would have saved me a lot of trial and error.
Problems I had were:
- Weeping head gaskets dripping coolant on the coil pack (ended up skimming cylinder heads & replacing rusty coil pack)
- Rumbling noises from rear (turned out to be rusty brake pads & discs. Once the pads had been freed the discs cleaned up and the noise stopped)
- Mystery misfire (after wasting time and money I eventually changed the plugs, that fixed it!)
- Clunks from front suspension (two faults: 1. roll bar links, a cheap fix 2. worn wishbone bushes. The wishbone bushes have metal inserts to prevent excessive movement. If you feel and hear a solid thump when you hit the brakes it is time to change the wishbone bushes).
When Vauxhall stopped selling Omegas I was thinking I would switch to a different marque for my next car bur this board has given me the confidence to start looking at Omegas again :y
Hello & Welcome :y
Hello and a very warm welcome to you Andy! :y
Hi, welcome to the forum. :y
Welcome along, Andy :y :y
welcome to OOF. :y
"Hello" and Welcome :)
Hi Andy and welcome to the forum ;)
HelloAndy,welcometo the Forum :y
Welcome to OOF mate :y
Hello and welcome to the Forum. :y :y
Good morning & welcome to the OOF :y
Welcome bud!
Hello and welcome :y
