Chat Area => General Discussion Area => Topic started by: holey head on 01 September 2007, 08:41:28
Title: hopefully get my car bk today!!!
Post by: holey head on 01 September 2007, 08:41:28
hi all,
as you may be aware my car has been in and out of garage since i bought it, only had it since april. well hopefully today i shall get it bk after having it helicoiled, breathers cleaned, heat shield put bk on, new cam cover gasket, ad plug wells cleaning!!!!!! then hopefully car will be bk as good as new and won't be seeing another garage for quite a while, well apart from getting new tyres!
just out of interest whose car is also in need of work doing at minute???
Title: Re: hopefully get my car bk today!!!
Post by: Crazydad on 01 September 2007, 08:45:15
can`t go  over 3000rpm  :'( :'(
at the moment waiting on a new Fuel filter hoping to resolve the problem with the new one :y :y
Post by: JamesV6CDX on 01 September 2007, 08:47:09
Any codes stored? Failed Crank sensor will rev limit at just under 4k on the V6..
Post by: Crazydad on 01 September 2007, 08:58:21
I will have to tell you the Story..................Draw up a chair...
Bought the car 4 months ago all was well.......... new belt, tensioners oil cooler head gasket water pump plugs oil filter (just been serviced)
then after about 3 weeks it started cutting out at 5200rpm i thought that i just needed to blow it out a little as the previous owner was an elderly woman who cr@ped herself doing more than 50 in it.
From then it started getting worse lack of power above 3500rpm very slow acceleration in 5th gear
i could feel it wasn`t happy
It feels as if its running out of Petrol, cutting out all the time when i`m running, tick over is perfect and as it is`nt always so i`m thinking fuel filter as i think this has not been done bought one from fleabay original Vx with clips for 11 pound including P&P
Zhought that it would of been here by now as i have this weekend off and wanted to fit
Post by: JamesV6CDX on 01 September 2007, 08:59:48
You will often get these symptoms with a blocked exhaust too...
Post by: Crazydad on 01 September 2007, 09:00:44
:o :o :o :o :o :o :o :o
how the hell can i check that
Post by: Baron Von Spongebob on 01 September 2007, 09:00:45
How much time you got, could be a long story. :(
Post by: Crazydad on 01 September 2007, 09:01:48
Morning Russ your up early did`nt sleep much then :-? :-?
Post by: Baron Von Spongebob on 01 September 2007, 09:03:12
Postman with a death wish  :-/
Post by: Crazydad on 01 September 2007, 09:05:33
Did`nt the GAURD SHEEP get him then ;D ;D ;D
Post by: Danny on 01 September 2007, 13:11:57
i was up at half 4, then off out posting letters! :y
Post by: Crazydad on 01 September 2007, 14:03:06
How sorry is this then. :-[ :-[
I normally work a 6 Day week with only sundays off,  :'(
but this weekend was a free one, So what did i do..........................yes you guessed it i got up at 4 in
the morning cause i coul`nt sleep any more   >:((Normally get up at 3 every Morning)
and started on the Forum again. :-/
There was only three of us on here JamesV6CDX  Davlad22 and myself with James already at WORK :y
Post by: davlad22 on 01 September 2007, 14:05:47
We'd just got home  :o
