Newbie Area => Newbie Welcome Area => Topic started by: nav on 18 September 2010, 20:16:51
Title: reprogramming key
Post by: nav on 18 September 2010, 20:16:51
Hi guys,
lost my key so pulled out the spare. works manually. took it to Perrys who want £40 to reprogram. OK but last year battery got drained and had to pay around £40 to get reset codes.
I have lost the codes I paid for but have now found the original card with codes. Are the codes I paid for the same as the original? or will I have to pay for new codes all over again?
Title: Re: reprogramming key
Post by: RobG on 18 September 2010, 20:39:46
Should be the same codes assuming nobody has changed the immobiliser & ecu`s :y
Friendly advice Nav. Any Q`s if you post in Omega help you will get a better response ;)
Post by: PhilRich on 18 September 2010, 20:45:31
Hi & Welcome  :y
Post by: Jimbob on 18 September 2010, 21:46:19
a key shouldn't lose the ability to talk to the car.
codes are for life.
it sounds like the key has lost sync...
put it in the ignition and turn to position 1 or 2, then press either button.
doors should lock and unlock (if the procedure needed doing) then bobs your uncle  :y
Post by: Kneepad on 19 September 2010, 00:38:23
 Welcome to the forum.   :y
Post by: Elitenut on 20 September 2010, 18:23:01
Hello and welcome to the Forum. :y :y
