Newbie Area => Newbie Welcome Area => Topic started by: davetyni on 21 February 2011, 20:29:27
Title: 2.6 V6 02 Sensor
Post by: davetyni on 21 February 2011, 20:29:27
Good evening all
I have a engine management light on, on my 2002 2.6 V6  which the dealer tells me is a faulty 02 sensor. I have looked on the exhaust system only to find that there 4 sensors fitted, which is the 02 sensor? if they all are, how can I tell which one is faulty.
Davetyni
Title: Re: 2.6 V6 02 Sensor
Post by: Omega_Dan on 21 February 2011, 20:30:44
Welcome to the forum :y
Post by: Lizzie_Zoom on 21 February 2011, 20:36:40
Hello and a warm welcome to you! :y
Post by: Entwood on 21 February 2011, 20:37:33
"Hello" and Welcome :)
tech questions best asked in "Omega help" as more of "them that know" read there than here .. :)
But the 2.6/3.2 all have 4 sensors and 4 cats. 2 "little" cats and 2 "main" ones, 1 of each in each downpipe. The sensors are either side of the little "pre-cats" and can give "false" readings quite frequently.
Moving the 2nd sensor to after the main cat  is one fix, another is to do a couple of tankfulls of premium fuel - esso, shell - rather than supermarket stuff as this can often "cure" the problem for a while.
You can do your own diagnostic check with the "pedal trick"
expect an 0420 and/or an 0430 error code.
Personally, when I get one of those I use my code reader to clear the fault and reset the light .. it usually stays out for about a year .. :)
Post by: sandune on 21 February 2011, 21:01:17
Hiya welcome aboard :y
Post by: x25dt on 21 February 2011, 21:44:42
Hello & Welcome  :y
Post by: Ploppy on 21 February 2011, 21:48:02
Welcome to OOF !  :y
Post by: dbug on 21 February 2011, 22:06:48
Welcome to OOF mate  :y
Post by: Seth on 21 February 2011, 22:42:22
Welcome bud! :y
Post by: Dishevelled Den on 21 February 2011, 23:22:25
How do you do Dave, welcome along. :y :y
Post by: Jimbob on 22 February 2011, 08:14:15
Hello & Welcome  :y
Post by: Cliffo B on 22 February 2011, 08:37:57
Hello,welcome to the Forum :y
Post by: davetyni on 22 February 2011, 09:43:43
Hi
Thanks for the welcome and advise, its great to know help is out there.
Dave tyni
Post by: mkirky on 22 February 2011, 11:10:34
Welcome to the oof
Post by: Elitenut on 23 February 2011, 19:16:48
Hello and welcome to the Forum. :y
Post by: Jusme on 25 February 2011, 11:59:41
Hi Dave, Welcome to the OOF..  ;)
Post by: Shark1e on 27 February 2011, 14:10:10
hello, greetings and welcome to oof :y
