Chat Area => General Discussion Area => Topic started by: CaptainZok on 05 September 2007, 21:05:31
Title: Paperclip test
Post by: CaptainZok on 05 September 2007, 21:05:31
Just pondering after reading another post about the paperclip test, could the useless trafficmaster button be rewired to the back of pins 4&6 of the diag socket to give a test button?
My thinking is its a push to make switch so would just need to be held in to activate the test.
I seem to recall when I had the radio out i disconnected a trafficmaster adapter loom with a couple of wires leading up towards the button so these should be fine.
So how do I get behind the fuse panel to connect, easy job or half the interior out to do it?
Hmmm might have a play tomorrow, Jaime is always telling people to run a paperclip test regularly.
This would make it simple, and finally find a use for that stupid button.
Anyone see any reason not to try this?
Title: Re: Paperclip test
Post by: VXL V6 on 05 September 2007, 21:26:52
...the button will be worn out in a month!!!!!
Post by: STMO123 on 05 September 2007, 22:50:32
Good idea. But I just wouldn't fancy having two pins in the diagnostic socket shorted out all the time. Especially as its only a two minute job anyway :-/
Now, if you could get Mrs Robot to read out the fault codes, that would be neat :y
Post by: VXL V6 on 05 September 2007, 22:57:59
Make her do both...... 'You are near M40 Southbound, severe delay, avoid oh and your crank sensor is stuffed so your going nowhere anyway'
Post by: Golfbuddy on 05 September 2007, 22:59:03
 ;D ;D ;D
Post by: CaptainZok on 05 September 2007, 23:01:20
Won't be shorted out all the time if its put through a push to make switch, only when you push it like a door bell does.
Post by: Baron Von Spongebob on 05 September 2007, 23:05:38
Got one of them
SWMBO.. :D
Post by: Markie on 05 September 2007, 23:07:31
Got one of them
SWMBO.. :D
Your swmbo is good with directions!?!?!?
You must have got a top of the range model  ;D
Post by: Baron Von Spongebob on 05 September 2007, 23:09:26
Got one of them
SWMBO.. :D
She don"t miss a thing   :o
