Omega Help Area => Omega General Help => Topic started by: flymike on 24 August 2006, 11:25:52
Title: 2.0 Ecotec rocker cover gasket.
Post by: flymike on 24 August 2006, 11:25:52
I have changed my rocker cover gasket three times and the dam thing still leeks. Is there any sealant i can use to help it?
I think the breather pipes need cleaning so that my job for the weekend and it should help it a little.
Title: Re: 2.0 Ecotec rocker cover gasket.
Post by: nixoro on 24 August 2006, 11:46:56
Hi there
This is one of things I think needs redoing, as mine has a leak but I think its from the front behind the Cams
This thread gives you the part number for the sealant
http://www.omegaowners.com/forum/YaBB.pl?num=1156308281
Good Luck with it  :)
Post by: Marks DTM Calib on 24 August 2006, 11:47:14
Its the breatehrs that are the problem....the oil will find the weakest seal if the system is pressurised and that will be the cam cover gasket.....be thankful as if it was sealed better it would probably be the crank seal...or worse!
Post by: nixoro on 24 August 2006, 12:37:17
This is more than likely my problem only I think the flame trap is gunked up along with the rear breather pipe.
