Omega Help Area => Omega General Help => Topic started by: Gwilym on 11 October 2006, 16:50:52
Whilst filling up today I decided to be very thorough and check all my levels of everything!
Petrol - Low (obviously as I went to the garage to fill up)
Coolant - Low (See previous thread on my leak - to be sorted Tuesday)
Oil - Fine
But Then
Auto Tranmission Fluid - after 5 minutes I stopped looking. On my Jeep Cherokee I had a dipstick but I couldn't find one on the MV6. Consulted the handbook and could find no reference to one. Is there one? Is it a viewing window or do I just wait for a warning on the dash!
I know I am showing a great degree of stupidity but HELP ME PLEASE
Its a bit more involved but, not to hard to do.
Checking the auto box fluid level (http://www.omegaowners.com/forum/YaBB.pl?num=1152783586)
Um. I take it as there is no easy way of checking that it is not a regular thing that needs doing? I don't have a problem with tranmission. I was just being efficient (and incompetent) and thought I would check.
How often do you check / or change yours?
Fluid change every 50K miles and check the level every 20K miles
Cheers. I will do it soon then
Funnily enough, I did mine today! I didn'tt fancy lying under a car as heavy as the Omega with it on axle stands and the engine running, so I asked my friendly Mot tester if I could check it on the 4 post ramp. didn't need much fluid at all and was a damn site easier ands safer. :)
Cheers Jim
I doubt mine has ever been changed. I really need to find a place that will do it, a couple have said no so far. Should I have them change or clean the filter? (149K) I was going to do the diff too. What is the suggested interval on that?
As an Omega uses the same gear box as it predecessor which had a dip stick tube on the auto box I wonder if it's possible to fit a dip stick to an Omega! Even my wife's Astra has a dip stick on the auto box!
I must admit, I found it strange that it didn't have a dip stick. Every other auto I've owned has had one!
Cheers Jim
The wife's clit hasn't.
I was quoted about £100 for vx dealer to change the ATF and filter.....that was Masterfit price tho..
HTH
Well your in for a shock....its not the same....its a later revision of, even the sump pan is a different shape with a different gasket etc.
The bottom line is that the gearbox 'shouldn't' loose fluid unless there is a leak.........which you would like to think would obvious.
Cheers Jim
Not just me then
Something i need to do as instinct - and nothing more apart from paranoi tells me something is starting to go amiss with my auto box, rolling back on hills whilst in drive ......fluid level check first.... :(
