		Omega Help Area => Omega General Help => Topic started by: Elite Pete on 12 October 2006, 23:26:36
				I going to change the oil tomorrow and was wondering if the sump plug has a brass washer or not.
 Cheers in advance :y
				Mine is a 98 2.5 and had the rubber washer, although I hadn't been sure beforehand and got both!
 Not sure if yours will be different as it's 3.0 though.
 Cheers Jonny for the email as well :y
				If yours has torx type, then integral rubber washer, if its normal bolt, copper washer...
				The torx type has an O-ring that should be replaced. They cost 12p from the dealer.
				I only change rubber one if its gone hard...  ...always change copper ones though...
				Thanks fellas :y
 Wish I'd known that ended up forking out for a complete sump plug last oil chenge. >:(
 No worries pal   [smiley=thumbsup.gif]
