Omega Help Area => Omega General Help => Topic started by: mijfife on 17 October 2006, 10:45:31
Title: Lambda interchangeability
Post by: mijfife on 17 October 2006, 10:45:31
Hi all, my eml is now only registering 2 codes, lambda and MAF sensor. Ive been looking at Gendan Automotive products and the lambda they list for the Omega 2ltr is also suitable for several other Vauxhalls. I'm not 100% convinced that the fault is with my lambda so the question is - will a lambda from another Vauxhall with the same multiplug work okay? I'm aware of the difference between Titania and zirconia, shame they can't be interchanged as I've got 2 universal ziconia ones in the garage  :(
   I'd like to try a second hand lambda before splashing out on a new one. I'll change the MAF first as I've read that a fault here car flash up the lambda code and vice versa!
Cheers Jim
Title: Re: Lambda interchangeability
Post by: JasonH on 17 October 2006, 13:10:39
MAF and Lambda fault codes can often be caused by air leaks, either on the intake side or the exhaust manifold.
I'd double check these areas first.
