Omega Help Area => Omega General Help => Topic started by: old cruiser on 11 November 2006, 17:26:15
Title: Cold running
Post by: old cruiser on 11 November 2006, 17:26:15
Does anyone get this with their 2.2 Omega; when engine is cold and around the 1500 -2000 rpm, I get what feels like driving over rumble strips, what I have noticed is that if fuel gauge is sitting between empty and 1/4 it's worse strangely enough but once engine is warm everything is fine.
Cheers Pete
Title: Re: Cold running
Post by: JamesV6CDX on 11 November 2006, 18:43:34
sounds like a little misfire
check the obvious like plugs etc
Post by: Taxi_Driver on 12 November 2006, 18:41:47
Nope, not got that on mine, sorry.
The only time my coughs a bit is when it first switches to lpg when its still warming up
Post by: Chopsdad on 13 November 2006, 21:02:46
I think I know what you mean - is it worse when you go downhill - ie foot off the throttle?
Cos mine gets little bursts of speed - and MID readout on fuel consumption shifts from 9999 to 45 MPG & then back again to 9999.  Sometimes feels like the wheels are unbalanced?
May just be settling in while the Lambda sensor heats up - but there'll be an expert along in a minute to advise.  :y
Post by: old cruiser on 14 November 2006, 09:02:22
Haven't noticed it worse downhill, but the strange thing is that with low fuel in tank i.e between empty and 1/4 is particularly bad after filling up it's vertually eliminated!, now beginning to wonder about the fule pump not coping with low fuel.
Cheers Pete
Post by: Marks DTM Calib on 14 November 2006, 09:08:53
It might be worth popping the level sensor/pump assembly out the tank and checking the pickup pipe....
Post by: rpont on 14 November 2006, 12:22:00
When was the fuel filter last changed? Since it's when the fule is low it's likely to be something to do with the pickup pipe/pump/filter area. Mine sort of rumbled when the EGR valve needed cleaning but the engine light came on as well then.
Post by: old cruiser on 14 November 2006, 14:18:52
Good point Mark, certainly worth checking pick-up pipe, is it easy to access and remove do you know off hand? can't remember from the last time I changed the fuel filter some months ago.
Cheers Pete
Post by: Auto Addict on 15 November 2006, 06:55:57
Cheers Pete
I used to get this before I cleaned out the throttle body and all the breathers, never had it since.
Post by: old cruiser on 15 November 2006, 08:55:33
Cheers AutoAddict might be the wya to go then, did you have any other running probs/ warning lights on with it at the same time before you did the clean out?
Cheers Pete
Post by: Auto Addict on 15 November 2006, 14:01:36
Cheers Pete
No.
Post by: old cruiser on 15 November 2006, 14:03:11
Ok thanks for that mate
cheers Pete
