Omega Help Area => Omega General Help => Topic started by: Markie on 19 November 2006, 10:17:50
Title: Strange little cold starting issue today
Post by: Markie on 19 November 2006, 10:17:50
Cant quite fathom this out.....
Went to start mv6 and it sounded initially like it was almost totally flat, after cranking for a few seconds its started to sound healthier but still not starting. Took about 15 seconds like this before it fired into lift. Now its -0.5 on the MID so freezing. However its not been far off that all week and i have never experienced it ( car always starts on turn of key)
Okay so i stopped it and restarted it and it fired immediatley - no signs anywhere of a flat battery - oh and battery is good and car is used every day.
So it must be damp or cold then,,,, :-/ yeah thats it....
Well thats what i thought BUT when car started i was asked to enter code for radio - suggesting an electrical break....
Any thoughts??? Its never happened before  :-/
Title: Re: Strange little cold starting issue today
Post by: JamesV6CDX on 19 November 2006, 10:32:29
The radio code does indicate that it's lost it's battery at some point
Sure your battery connections are all good? And the battery is good?
It needs a godo battery to crank that V6, especially on a cold day!
Post by: Markie on 19 November 2006, 10:36:44
hmmmmm battery wasnt good - but taken out 6 weeks ago and fully charged over 3 days.
Since then its been spot on and the car has been used daily - thing is, once it fired up it sounded perfect as usual. May just go buy a GO from vx seeing as i now have my trade card  :-/
Ive noticed in the past little things that tell me the battery is low ( sure we all have) like the windows get slower and the warning bleep when your lights are on when the keys are out the ignition gets a little slower sounding but everything seems fine in that sense this morning....
Post by: TheBoy on 19 November 2006, 13:19:53
Sounds like battery shafted.  Battery efficiency drops with temperature, so its coming to light now that its got a bit nippy....
Post by: x25xe on 19 November 2006, 21:42:19
Battery may well be on it's way out BUT.............................
I had a similar sort of thing last week with my V6.  It took a long time to fire, a good deal longer than normal.  I was talking to my mum at the time and when it started, she said "I thought that it was not going to go".
There was no evidence of a power loss, radio still had it' memory etc.
This is the first time that the car has done this, and a new battery (Vaux GO) was fitted earlier this year.  All very strange and it has not, touch wood, done it since.
Any thoughts???
Post by: TheBoy on 19 November 2006, 21:45:56
The thing that makes me think its the battery (esp with the cold snap up in Scotland) is that Markiec said it seemed flat.
Post by: Auto Addict on 19 November 2006, 21:51:13
Shrewd diagnosis.....
Post by: STMO123 on 19 November 2006, 21:52:11
Same symptoms as mine a while ago Markie. My battery was fine but low output from alternator
Post by: EddieX on 19 November 2006, 22:53:58
Can I do the joke about "what shape should it be"? .......... pretty please  ;D ;D ;D ;Dß
Post by: Pete Elite on 19 November 2006, 23:15:00
   Sounds to me like a cell is on it way out :(, not taking a full load!!!
 Only takes a good cold snap to catch you out :exclamation.
 Hope you get it sorted, nothing worse than messing about on a cold morning.
 Pete :y.
Post by: Markie on 19 November 2006, 23:42:28
wel i have got a battery of batteries in the er garage. I remembered this as i set the fireworks off next to the garage a few weeks back  :o
But for my own car its gotta be a new one so i `ll go spend a few pennies this week on a new one  :y
Thanks Guys - never thought the cold would affect this - if only id use my garage for my daily cars instead of projects it could be tucked up at night  :(
Post by: Taxi_Driver on 20 November 2006, 06:30:57
Only thing im not sure about is that Markiec says it sounded better after a few secs, so presumably it started to crank over faster.......which is the opposite id expect from a knackered battery  :-/
Post by: Markie on 20 November 2006, 09:27:48
this is true Dave - for a few seconds i was thinking oh oh flat battery, as i was about to take key out to get jumps i noticed it suddenly started to sound more positive. After about ten seconds it sounded fine, turning over ok, just not starting.
Then Blam! Off it went.
I stopped and started it 3 times immedatley after that without driving - and every time it started as normal ( within a few seconds)
Havent been out yet so will report back todays starting situation - its just as cold today !
No rush though i have 7 days off on holiday.
Post by: nixoro on 20 November 2006, 10:44:20
Could this be a possible problem with either the crank sensor or starter motor perhaps a sticky solenoid.
Post by: Chopsdad on 20 November 2006, 12:55:59
Crank sensor - look for a hidden voodoo bratz doll  ;D
Post by: Markie on 20 November 2006, 13:13:57
i wondered how long before someon mentioned the crank sensor  ;D
