Omega Help Area => Omega General Help => Topic started by: Pete Elite on 08 December 2006, 01:06:42
Title: Intermittent Miss.
Post by: Pete Elite on 08 December 2006, 01:06:42
Hi all,
       My 96 3.0L  Elite has got an intermittent miss.
 On tick over it's fine and if you use light throttle movements it builds up speed ok but as soon as you rapidly increase throttle it misses badly.
 This lasts for some time at which point you could throttle her up and it fine again.
 Any ideas as to the probable cause :question.
 Cheers,
           Pete :).
Title: Re: Intermittent Miss.
Post by: JamesV6CDX on 08 December 2006, 01:17:40
Remove and check each plug lead, one by one, and make sure there's no oil in the plug wells. A very common cause of intermittent misfires!
Post by: Markjay on 08 December 2006, 07:46:57
Also - spark plugs problems, air/vacum leak, blocked fuel filter, dirty injectors...
Post by: Marks DTM Calib on 08 December 2006, 09:25:48
Also make sure the spark plugs are torqued down properly
Post by: omega si on 08 December 2006, 10:08:50
Sounds pretty similar to my 2.5  :'(
Gonna have a good look at the mutha this weekend if the weather will let me
Post by: Andy B on 08 December 2006, 19:54:55
DIS unit? Crank sensor?
Post by: JasonH on 08 December 2006, 21:19:15
My money would be on HT leads....
Post by: Pete Elite on 08 December 2006, 21:33:58
 Thanks for all your replies.
 Will have a good looksee.
         Cheers,
                   Pete :y.
