Omega Help Area => Omega General Help => Topic started by: stuvaux on 19 December 2006, 20:46:38
Title: rear suspension
Post by: stuvaux on 19 December 2006, 20:46:38
the drivers side rear wheel on my car looks as though it has been pushed back
about an inch (since the car was wrote off)
does anyone have any ideas about this?
how is the rear suspension set up?
could it just be that a bush has got damaged somewhere?
there is also a clunk from that side when driving over small bumps in the road - this has been more noticable since the car was lowered
any help would be much appreciated
thanks,  stu  8-)
Title: Re: rear suspension
Post by: B52 on 19 December 2006, 20:55:52
erm - not sure but id not be driving it until thats sorted...
Post by: Marks DTM Calib on 19 December 2006, 20:57:50
Well, the rear tie rod adjusts the rear toe (also has a small affect on camber)......and given the pivot is a fair way forward of the wheel would also make teh wheel look like it was furtehr in if miles out.....are the tyres wearing evenly?
Post by: stuvaux on 19 December 2006, 21:05:51
the tyres seem to be wearing ok, although they have not been on for that long
otherwise, the car drives fine
the gaps on the side of the other rear wheel seem about the same
on the drivers side, it is as though the wheel has been pushed towards the back of the car about half an inch
 8-)
Post by: Marks DTM Calib on 19 December 2006, 21:17:13
Can you get a tape measure and measure the distance between the centres of the front and rear wheels on both sides.....plus, what side and where was the accident impact.
Post by: stuvaux on 20 December 2006, 15:16:52
thanks mark
do you mean measure the centre of the wheel to the bumper/door edge?
in the accident, i mounted a kerb, with the drivers side front wheel hitting it first, then it must have been the front passenger side
the car ended up looking as though i had parked it on the path, having turned through 90 degrees to the left!
the front subframe was replaced, as it was out of shape. also, both front wishbones and droplinks, and the drivers side bearing was replaced
the main impact seems to have affected the drivers side of the car, although it was the two front alloys that were buckled completely - the rear two are ok
stu,   8-)
Post by: Marks DTM Calib on 20 December 2006, 15:31:39
No, measure between the front wheel centre and the rear wheel centre.....to measure the wheel base effectively.....on both sides.
Post by: stuvaux on 20 December 2006, 15:33:01
these are the measurements (taken from centre of wheel to bumper/door edge):
Front drivers side :  front 380mm/rear 360mm
Front pass. side    :  front 361mm/rear 361mm
Rear drivers side  :  front 392mm/rear 360mm
Rear pass. side    :  front 380mm/rear 370mm
the `front` measurements are from the wheel centre towards the front of the car, and the `rear` are from centre to rear of car
thanks,  stu   8-)
Post by: stuvaux on 20 December 2006, 15:33:58
ignore that last lot then
i'll go and check them!
Post by: stuvaux on 20 December 2006, 15:40:54
sorry about that!
drivers side is 273cm
passenger side is 274cm
does that help?
i thought the drivers side would be longer if the rear wheel has been pushed back!
thanks,  stu
Post by: stuvaux on 21 December 2006, 19:35:44
does that help at all mate?
i know the drivers side is correct (i checked the technical specs for the car), but the passenger side is 10mm too long!
Post by: The Barge Captain on 22 December 2006, 01:29:59
I would try measuring from hub centers to a fixed point on the bodywork that can't have been knocked out of line and see if both sides match.
Post by: stuvaux on 22 December 2006, 11:15:38
the measurements above do that
they are all different, so i am really still none the wiser!
any more help on this would be much appreciated!
thanks,  stu   :-?
Post by: Taxi_Driver on 23 December 2006, 15:47:28
From the measurements you have taken, it sounds as tho the chassis is fairly straight but the body is not sitting on the chassis squarely.  :( But dont take my word for it, its just my interpretation of your measurements
As you had impact on the wheels that'll be the reason the insurance comp wrote it off. Any impact on the wheels and they have a chassis/body alignment done......last time i asked at an accident repair centre.....it costs £700 to have that done  :o
Post by: stuvaux on 23 December 2006, 19:59:10
i am just about to have the wheel alignment done
i'm not sure how much of an effect that will have, but here's hoping!
my brother works in a bodyshop, and when he took it there after the accident, they said the chassis seemed to be in alignment.
there was a small kink in the drivers side front leg, which they sorted out
thanks,  stu   ::)
