Omega Help Area => Omega General Help => Topic started by: Essex_Andy on 29 December 2006, 17:52:39
Title: Worthwhile upgrades?
Post by: Essex_Andy on 29 December 2006, 17:52:39
Just browsing on E-Gay as you do and found a couple of rear sunscreens as well as crusie modules and stalks for my 1998 model.
(I think on the mini-facelift 1998 models cruise is just a plug a play affair, no ECU re-programming though please correct me if I have been given duff info)
The 'spare' lead(s) inside the left side of the boot, are they the power leads for the sunscreen?
and as for cruise I have been told and read that the module/actuator lives on the inner wing but I cant find the harness connector....will it be lurking under the windscreen scuttle/tray?
Any help greatly appreciated.
Still waiting for late Jan early Feb to fit the 3.0 cams. Ride is good on the new irmscher springs and shocks. Need to go back to Wheels In Motion soon for the 2000mile final fine tune.
Also probably looking for a set of 17" or 18" rims...but cant find any in sensible money....most seem to be cicra £700+
Title: Re: Worthwhile upgrades?
Post by: TheBoy on 29 December 2006, 17:54:32
Cruise loom is bolted to top of drivers side front suspension turret.
Rear blind loom is a 3 pin plug, up under shelf on left hand side...
Post by: Essex_Andy on 29 December 2006, 17:57:50
Thanks fella
I just cant find the wiring plug that goes to the cruise 'doofer' that bolts to inner wing/strut turrett
Post by: TheBoy on 29 December 2006, 17:59:16
Thanks fella
Quite big, 10 pin plug, some people confuse it for the diagnosics plug....
Post by: TheBoy on 29 December 2006, 17:59:52
Take a piccy of your engine bay, and post it here....
Post by: Essex_Andy on 29 December 2006, 18:24:31
Will do tomorrow...bit dark now :y
Post by: Jay w on 29 December 2006, 18:24:37
i have a working cruise unit for a miggy with cable as well, PM me if interested.....
Sorry for thread hijack
Post by: TheBoy on 29 December 2006, 18:27:51
Remember, the stalk needs to be the 4 wire stalk (about £30 +VAT new, not worth buying 2nd hand).
I seem to recall the cruise throttle cables are different between the different engine sizes...
Post by: Martin_1962 on 29 December 2006, 18:45:32
LEss than that from Autovaux
Post by: TheBoy on 29 December 2006, 18:48:55
inc p&p?
Post by: Essex_Andy on 29 December 2006, 20:16:11
PM sent
Post by: Martin_1962 on 29 December 2006, 20:37:27
inc p&p?
I think so
Post by: TheBoy on 29 December 2006, 20:42:44
inc p&p?
I think so
Worth knowing, esp if they are brand new, and not recon stuff should by other companies. Recon ones don't last (assuming they work at all)
Post by: rpont on 29 December 2006, 20:54:02
Here's a picture of where it should be sitting. It's the plug between the turrett and the brake fluid bottle.
(http://www.infohitsystems.ltd.uk/Gallery/Car/P1010054-2.JPG)
Post by: TheBoy on 29 December 2006, 21:13:46
Also, the cruise unit is the cube shaped unit under brake reservoir, to left of exhaust in that piccy...
Post by: Essex_Andy on 29 December 2006, 21:14:28
Right been outside with my torch and found the multiplug by the strut top...someone looped it under the master cylinder and back under the windscreen scuttle
However a couple of things to sort though:-
1) I have the extra electric coolant/heating pump mounted on drivers side inner wing so I need some adaptor plate from vauxhall to mount cruise actuator and electric coolant/heating pump
2) I need the cruise control type brake pedal and clutch pedal switches (i'm guessing the other plugs and wiring are present under the dash/steering colum area)
Post by: TheBoy on 29 December 2006, 21:16:50
Yes, all wiring is in place...
Post by: Essex_Andy on 29 December 2006, 21:21:24
any idea on part number or name of the adpated fitting bracket/plate for omegas that have the additional electric coolant pump?
Thanks everyone...beers and bacon sarnies waiting when you lot turn up and help me do the cam swap and fir new belt and flush out breather pipes.....keep early feb clear :y
Post by: rpont on 29 December 2006, 22:20:28
Not quite, that's the steering box. I haven't got the cruise module fitted in that pic.
I have the additional coolant pump fitted and Vauxhall didn't fit the pump when cruise control was fitted (we discussed this some time back and no one who had air conditioning and cruise had the pump). Some have bought a pump holder and drilled holes in the cruise bracket to fit it. I used the existing pump bracket but bent back on itself to get the pump in. The URL below and the next 4 pics show what I did, I wasn't happy with the attempt in the first two pics so redid it for the next two. It's a bit of trial and error to get the bracket just right so that the pump isn't touching the engine pipes and is clear of the air filter box.
http://www.infohitsystems.ltd.uk/Gallery/dirwrap_photo.sh?rt=wrap&path=Car/P1010054.JPG
Post by: TheBoy on 29 December 2006, 22:25:36
Doh! Serves me right for only glancing at picture  :-[
Post by: rpont on 29 December 2006, 22:56:52
You had me scratching my head for a bit there. I was sure I hadn't got the module when I took the pic of where the breather box went before I took it off. With the heads missing from the engine I can see how a quick glance could come up with that idea though.
Post by: Essex_Andy on 29 December 2006, 23:01:43
ok next question(s).....
rear sunblind thingy....nothing in my haynes manual about fitting/removing etc
Is it an easy retro-fit upgrade...anyone got a switch going?
Thanks again
Post by: Chopsdad on 29 December 2006, 23:14:59
You could Email this guy selling a leather interior from an Elite - switch may still be in the dash if you're lucky http://cgi.ebay.co.uk/Vauxhall-Omega-Leather-Interior_W0QQitemZ300065124586QQihZ020QQcategoryZ10404QQrdZ1QQcmdZViewItem
Post by: hotel21 on 30 December 2006, 10:24:46
......I have the additional coolant pump fitted and Vauxhall didn't fit the pump when cruise control was fitted (we discussed this some time back and no one who had air conditioning and cruise had the pump). .....
Sorry to butt in - check out the howtoo for fitting cruise to a prefacelift.  Shows where the various bits are and what they look like.
http://www.omegaowners.com/forum/YaBB.pl?num=1166374649            :y
VX DID fit cruise, climate control aircon and the extra pump from the factory.  All parts to retrofit are available.
Mark DTM tells me that the mounting rubber on the end of the radiator for the similar pump that is there is available from a scrappies and can be fitted to the cruise frame to do the same job.
HtH
B
Post by: Andy B on 30 December 2006, 12:28:58
I might be missing something here but ..... My mini face lift Elite has cruise & A/C but the electric aux pump isn't fitted under the header tank, it's at the top of the rad - passenger side.
Post by: rpont on 30 December 2006, 13:07:42
That's the one for radiator cooling, all the v6's have it I believe.
Post by: Essex_Andy on 30 December 2006, 13:31:47
I lost out on one of the sunscreens on e-gay and having taken a second look at the parcel shelf and under tray seems like a lot of messing about for something not really going to use much....was thinking about bright sunlight on my young son's eyes.
Any tips on retro fitting?
Post by: Andy B on 30 December 2006, 14:20:44
The only time I lower mine is when I'm reversing up to a wall (when my tow ball isn't fitted  ;) )
Post by: Andy B on 30 December 2006, 14:22:42
:-/ So what's the electric pump under the header tank for then? I thought it was just an age thing that dictated where the aux cooling pump went.  :-/
Post by: TheBoy on 30 December 2006, 16:11:33
As per Haynes, though you may or may not have to remove trim from pillars (its tight, but can sometimes be done without....
Post by: Andy B on 30 December 2006, 16:17:24
Last summer I eventually removed the blind/rear parcel shelf to look at why my screen wasn't rolling up properly. I had everything possible removed from the back of the car and the bugger still wouldn't come out. It came out when I lost my temper with it and really pulled it. A bit of the window glue was holding the parcel shelf in!  >:(
Post by: Essex_Andy on 30 December 2006, 16:27:53
Sorry for being a dumb arse but cant find the sunblind section/removal and re-fit in my haynes manual?
Post by: TheBoy on 30 December 2006, 16:54:30
Sorry, look at rear parcel shelf removal...  ...difference it 3 bolts that protrude into boot space if you have a blind as well....
Post by: Jay w on 30 December 2006, 17:33:20
this may help a bit.....
http://www.omegaowners.com/forum/YaBB.pl?num=1152745304
