		Omega Help Area => Omega General Help => Topic started by: omegaV6CD on 31 December 2006, 12:40:30
				Does anyone know what the ECU number should be in a 2.5 t reg omega? I checked mine and it is 261 203 588. Is that correct?
 i did some search on the net and i can see that this is the same number for the 3lt cars.
 Thanks in advance
 Kostas
 Thanks in advance
 Kostas
 I guess yours is this one then....
 UNIT, ELECTRONIC CONTROL, FUEL INJECTION SYSTEM (IDENT HH) (BOSCH 0261203588) X25XE S1035397-  90510665 62 37 325 1
 Note: EXC.LEADED FUEL MODIFICATIONS,GULF COUNTRIES
				For 2.5 cars prior to this ECU, this ECU is the replacement...
				3.0l part appears to be different...
 Thanks in advance
 Kostas
 Thanks a lot mate!
 Thanks in advance
 Kostas
 You might know what the codes mean? other than the X25 XE? Or do u have any interesting info with regards to the ECU?
 Thanks again
				The ident is just that, to identify ECU type. Bosch part number is obvious, as is Vx part number (starting with 9), and the chassis break points (Sxxxxxx onwards...)
 I don't know any more, sorry.
 No probs, thanks again!
