Omega Help Area => Omega General Help => Topic started by: mar892ree on 30 December 2006, 15:33:19
Title: Front door card removal
Post by: mar892ree on 30 December 2006, 15:33:19
Hi chaps !!
OK, have followed FACELIFT front door card removal instructions to the letter !
I still cant get the bloody door card off the door !
Seems as if there is another fixing somewhere in the middle ri9ght on the top edge of the card !
Had another look at the " how to" , and it mentions the lip or locating strip on the top edge of the card, might be a bit tight !
Didnt , obviously want to force things too much, but i can not get the bloody thing to fully release from the door !
Shall i give it a serious whack or thump on the bottom of the door card , in an upwards direction as suggected in the how to !
Has anyone else had a really tight top edge on a facelift door card !!!
Ohhhhhhh and yes i have removed ALL screws/trims etc .
Cheers
Mark
Title: Re: Front door card removal
Post by: TheBoy on 30 December 2006, 16:17:50
Hi chaps !!
Cheers
Mark
If its just top edge, then yes, give it a nudge.  If its in centre of card, its the secret screw under handle....
Post by: Taxi_Driver on 30 December 2006, 17:29:22
Well if you have definately got 8 screws......there arent anymore.....so give it a whack  ;)
Post by: JasonH on 30 December 2006, 18:22:38
I popped mine off using a big bolster, protecting the paintwork with a towel.
Came off a treat, all clips intact.
Post by: Markjay on 30 December 2006, 19:14:40
Yep... a whack... as said, just make sure the 'secret' screw is out. And mind the door lock lever thingy when you whack it upwards.
Post by: mar892ree on 30 December 2006, 23:24:25
Cheers chaps, will give it a nudge  ;D
Ohhhhhhhh guess why i am having to remove the door card !!!!!!!!!!!1
Yep, check strap faliure !!!!
Mark
Post by: STMO123 on 30 December 2006, 23:30:28
Ah! The 'death click' :(
Post by: mar892ree on 31 December 2006, 09:00:22
 ;D ;D ;D ;D ;D ;D ;D ;D
Bit more than death click !!
More like its died - as it dont click anymore  :o
Its all ripped out of the door !!
Oh well never mind- worse thinga happen at sea  ;D
Post by: TheBoy on 31 December 2006, 12:33:21
You shouldn't have let it get that far - for sake of 20p, you should have sorted it before....
I hope this is a warning to others though...
Post by: Andy B on 31 December 2006, 14:26:45
There's more to it than just the plastic bush. (IMHO it shouldn't be needed in the first place if it was so neccessary why wasn't it fitted to Senators Carltons Mantas etc) The check strap had already been pulled through the door skin of the driver's door before I bought my car although the plastic bush was still present & correct. The passenger door very recently went from being perfectly OK to almost pullung through the door within a couple of 'open & closes'. I now have a reinforcing plate on either side of the door skin on each front door. I think that's more a case of penny pinching on Vx's part trying to hold a heavy with the minimum of cost. I bet there's no problems with Paul M's 8 series doors, and they could double up as barn doors if required!!
Post by: TheBoy on 31 December 2006, 14:31:18
I disagree - changing the bushes at first sign of noise would appear to stop the strap breaking...
Post by: Andy B on 31 December 2006, 14:39:21
We'll have to agree to disagree then  :D How do you explain the fact the plastic bush in the driver's door has been transfered to the new check strap with no problem/noise? The old check strap was in the bottom of the door attached to the bit of sheet steel that used to be the front of the door.
The first noise that my passenger door made was the crack as the front of the door around the check strap started to give way.
Post by: TheBoy on 31 December 2006, 14:52:14
OK, as you say, we will agree to disagree ;)
I would change those bushes anyway, even though you have now reinforced the strap, to stop it causing extra stress, as I suspect those bushes are shot...
Post by: Andy B on 31 December 2006, 15:19:18
When the bushes are Donald Ducked completely and there is movement of the door before the check strap starts to move I can see that the kick of the strap against the door carcass will cause premature failure of the door, but the bushes are OK - honest, I can tell a goosed bush from a good bush - engineering is what I do for a living - Both doors now open & close smoothly even with the "shot bushes"  ;) We'll have to compare when we ever meet, assuming I put up with the car for that long.  :o
Post by: Hemppa on 31 December 2006, 16:25:24
My door strap also ripped totally out of the door, but the plastic bush was still like a brand new.
And when I checked my (old) door strap, I noticed it has two metallic "rollers", which were not aligned with the rod anymore, because their holes were very worn.
So I THINK this is the reason why my door strap ripped off.
Hopefully some of you understands my bad english. ::)
Post by: Andy B on 31 December 2006, 16:33:27
My door strap also ripped totally out of the door, but the plactic bush was still like a brand new.
We understand perfectly. I think I can speak for most of us in saying that your English is better than our Finnish.  ;D
Post by: Taxi_Driver on 31 December 2006, 16:44:19
I had the 'crack of doom' well more like a clunk when opening the drivers door.....changed the washer......think it was 10 or 14p vx charged me.....and a silent opening door.....for a few days....then it started to squeak instead.....squirt of white grease.....fixed that  :y
Examing the old washer, it had worn quite a bit compared with the new one.....after all its only plastic.
Also before changing the washer you could see the bolt moving around quite a bit as you opened and closed the door.
Last time i drove my vectraB i noticed thats got the crack of doom on the drivers door to......and thats a lot lighter door.....when it comes back for a service next....i'll be changing that washer too  :)
Wether changing the washer stops the check strap breaking......dont know....but it certainly stops it making a cracking noise.
Post by: TheBoy on 31 December 2006, 17:39:30
If the washer is worn, it can cause it to stick, putting extra stress on it, which is possibly most common reason for strap failure. Obviously, there are other possibly causes as well...
Post by: mar892ree on 31 December 2006, 21:30:02
Well i dont care  ;D ;D ;D ;D
Mine was broken before i brought the car, just too bloody lazy to change/repair it before now !
The section on the front shut of the door that takes the check strap has ripped out !
Will access situation, and affect a repair ! If i find an alternative to welding a section back in i will do a " how to"
I have access to laser cutting facilities so repair plates can be made in any thickness etc , as i'm not immpressed with the strengthening plates purchased from VX !
Post by: Andy B on 31 December 2006, 22:57:26
I copied the plate I bought from Vauxhall but cut an 1/8" off each end to allow it to fit on the forward side of the door skin - the bit where you can't see where the check strap emerges from the door - and put the full sized reinforcing plate on the inside of the door. Not that they'll be any stronger but the plates I made were in 1.5 mm stainless - I didn't have the motivation to file 3 mm plate.  :-?
It did take me nearly 3 years to get around to fixing my door, it was when the passenger door went that I decided to sort it!  :-[  ;D
Post by: mar892ree on 01 January 2007, 02:27:55
Fancy some 10mm ones  ;D ;D ;D ;D ;D ;D
Post by: mar892ree on 01 January 2007, 02:29:46
also have access to projection welding equipment, so can spot weld nuts on to !
Might be useful to have some captive nuts on the inside plate, so making fixing easier !
Post by: Andy B on 01 January 2007, 10:27:46
You bolt through to the captive nuts on the actual check strap anchor plate.
Post by: STMO123 on 01 January 2007, 19:32:28
Mark
What does it say underneath your avatar batman? ;D ;D ;D
Post by: mar892ree on 01 January 2007, 22:53:32
LLOLLLOLLL BUT this time i used my fist  ;D ;D ;D ;D ;D
Came off a treat! Ohhhhhhhhhh and a New Years resolution too, non use of hammers  ;D ;D
Post by: Paul M on 03 January 2007, 22:00:55
So what's the solution for someone like me who's driver's door is already busted (check strap mount ripped from inside the door itself, was like that when I bought the car) and doesn't have access to welding gear?
I have to add, regardless of the outcome of the debate as to whether the plastic bushes being worn causes the failure, I still say it's a poor design. Either the check strap seizes too easily, the door skin where it's mounted is too weak, or a combination of both. I've seen some really poorly maintained cars in my time, some of which the oil was like treacle when I checked and it was amazing they still ran reasonably well considering, yet not one of them had a broken or missing check strap. I'd be quite willing to bet the only time the check strap on those cars would ever get any "maintenance" would be when the door completely refused to close even after a good shove, yet they still seemed to be in one piece. The only problem I ever recall is a really annoying squeak on every open or close, which of course also went ignored until I greased it due to the insanity-causing potential ;D.
It's one of those things, all cars have their faults and I think it's hard to argue that this is a definite fault on the Omega.
Oh and as it was mentioned by someone above, the doors on my 840 are as solid as they probably were when they left the factory. The check straps have never (to my knowledge) needed any maintenance, they don't make any noise and still look like new. Partly this will be down to them being covered by a small rubber gaiter that stops all the crud getting in and causing problems in the first place, but I'm sure it's also a much more robust design.
Post by: Andy B on 03 January 2007, 22:56:29
My driver's door was goosed like yours when I bought my car. What has worked so far on my door is sandwiching what is left of the front the door with 2 reinforcing plates :- 09 195 961 I put one inside the door between the chech strap base plate and the remnants of the door, and the other, cut down a little to allow access, in the 'hole' at the front of the door where the arm of the check strap emerges. So far so good!  :y
The 'correct' repair seem to me to be too costly in time alone. ie Remove door, then remove its contents. Drill out the spot welds that fasten the  "front door stop mounting bracket," Purchase another mounting bracket :- left side 90 458 147 (PS you won't find this or 90 458 148, the opposite hand for the passenger door in EPC cos if you remember Vauxhall never had any problems with their door check straps!!!  :-?)
Oh and as it was mentioned by someone above, the doors on my 840 are as solid as they probably were when they left the factory.  ........ I'm sure it's also a much more robust design.
That'd be me  ;D
BUt I don't think the fault is down to the actual check strap & spring, it looks very similar to the Senator's - & they didn't have any problems with the doors. I think it's due to the cut price design of the front edge of the doors & posts. If you gently  ;) bounce the front & rear doors open against their stops, you can see both the A posts  & B posts flexing.
Post by: sounds2k on 03 January 2007, 23:34:50
it's bad and cheap design. You'll notice that it's only really the front doors that "suffer" from this problem, the check strap on the rear doors is fixed onto the main door frame (double skinned IIRC) rather than a single thickness skin on the front doors. However, when the front door is re-inforced, then the bracket on the 'A' pillar becomes the weak point - on mine, this bracket is held on with 4 spot welds and one has come off already ...  ::)
We know miggy doors are heavy, but I reckon Vx probably used the check straps off a vectra whose doors are much lighter ...
Post by: Andy B on 03 January 2007, 23:49:48
The check straps aren't really the problem. It's the mounting point of the Omega doors that's the weak bit. (is any one able to check if the check straps from Omegas, Carltons & Senators are the same? they certainly look it!)
Post by: mar892ree on 04 January 2007, 20:33:38
No, the check links are NOT the same number on the Vectra as the Omega !
Post by: mar892ree on 04 January 2007, 20:35:34
Not the same part No on the Senitor either
Post by: Hillper on 06 January 2007, 10:21:36
Did you get the card off?
The horizontal plastic strip under the card can be very well located in the metal clips.  You need a good thump or try levering it out with a long levering thing.
