Omega Help Area => Omega General Help => Topic started by: ohmegod on 18 January 2007, 18:33:44
Title: Mysterious switch
Post by: ohmegod on 18 January 2007, 18:33:44
I know your all going to shout at me,but i have only just had the car and have no owners manual.............but what the heck is the little switch in between the electric window switches do?.Theres a green and red led when switched forward or back???? it doesnt seem to do anything..........
Title: Re: Mysterious switch
Post by: Bo Bo on 18 January 2007, 18:42:31
It turns off the rear electric window switches so they can't be used from the rear.
Post by: ohmegod on 18 January 2007, 18:43:40
Thanks bud :y
Post by: TheBoy on 18 January 2007, 19:00:00
Yes, and the LEDs on the rear doors should go out to show they are not active...
Post by: Bo Bo on 18 January 2007, 19:12:48
Never noticed that  :-[
Post by: TheBoy on 18 January 2007, 19:15:49
You probably don't sit in the back much. Plus, I think you are (normally) responsible enough to have the windows enabled...
Same principal as the fronts - if the yellow LEDs are on, that switch will operate window, if they are off, that switch is disabled for whatever reason (eg ign off etc)
Post by: Bo Bo on 18 January 2007, 19:21:43
Yep, only sat in the back once when bro was driving, something to check in the morning.
Post by: Markjay on 18 January 2007, 21:56:38
I find that switch is actually quite useful, what I don't understand is why the child locks on the doors are the same as they were 20 years ago, i.e. a mechanical lever on the door side? My other-half's Previa has a switch next to the driver's controls that locks all the doors so they can't be opened from inside.
Post by: Bo Bo on 19 January 2007, 07:16:34
& they do  :y
