Omega Help Area => Omega General Help => Topic started by: Palmo on 24 January 2007, 23:41:54
Title: Carbon Canister on Diesels
Post by: Palmo on 24 January 2007, 23:41:54
Does anyone know for sure if the Carbon Canister as fitted in the front drivers side wheel arch as to petrol models is also fitted on the 2.5 TD?
I have cross referenced this on the Vauxhall TIS and cannot find direct reference to the TD having one except in Technical Service Bulletin E0000914 entittled 'Engine Misfiring on Snowy or Dirty Roads, Especially at low temperatures'. Here reference is made to the Carbon Canister and the X25TD engine.
Can anyone confirm if the TD has one or not?
Title: Re: Carbon Canister on Diesels
Post by: Palmo on 25 January 2007, 18:12:19
Surely someone knows?
Post by: Auto Addict on 25 January 2007, 19:23:39
Sorry, I wish I could help :(
Post by: BigCat on 25 January 2007, 22:31:59
Hi Palmo, if you look in TIS200, and compare documents 00004410 and 00004409 (KTA-1709) in Group L (Fuel and Exhaust System), you'll see that there is a reference to an activated carbon canister in the petrol document (00004409), but no mention of it in the diesel document (00004410).
The carbon canister's purpose is to absorb hydrocarbon vapours (petrol fumes to you and me) and prevent them entering the atmosphere and causing smog. As diesel is far less volatile than petrol, I suspect that diesel vapours contributing to smog are less of an issue with regard to pollution, and therefore there is no requirement for the carbon canister.
Post by: wombatcurry on 27 January 2007, 09:52:33
I've not seen one on mine..what does it look like/how big is it????
Post by: tunnie on 27 January 2007, 10:36:27
Palmo - Send a PM to 'omegatoy' he knows the Omega diesel inside out  :y
Post by: Omegatoy on 27 January 2007, 19:47:42
as i said to palmo via pm diesel doesnt have one but wasnt sure if they fitted it to newer models as vxhsall have some silly ideas sometimes ;D
but was pretty sure they didnt!!
