Omega Help Area => Omega General Help => Topic started by: Paul M on 27 January 2007, 01:56:24
Are the controls for opening and closing the air vents supposed to be illuminated on a 1998 MV6? None of mine currently light up but I've seen a pic with them illuminated. If so first check is the bulbs, where are they located (I assume it uses a light guide type thing to channel the light to the right places).
the on and off indicators should light up
not exactly sure of where the bulbs would be located - presumably just behind the appropriate vent, via a light guide as you say
Side or centre vents?
Both.
Not sure if it helps but the air vent dials on my 2000 CD estate are illuminated.....
Side ones illuminated by bulb that is accessed from semi circular panel accessible with door open.
Centre ones need vents removed...
OK cheers I'll have a look tomorrow if I get a chance before it's dark, been busy with other things today.
