Omega Help Area => Omega General Help => Topic started by: Spam95 on 10 February 2007, 17:43:35
Hi everyone
I've just bought my forst Omega. I need a huge estate as I cart around gear for a small duo I'm in. I bought it off Ebay. A truly frightening experience. What happened was I made a BEST OFFER bid of a ridiculously amount and the bloody thing came up. I was more surprised than the seller. It turns out to be a 38000 m Y Reg green 2,6 manual estate that was an ex motability car. The HPI was fine and generally the car is is lovely condition. I have already learnt from your site to have the timing belt change and a full service.
I have a few problems
Firstly the windscreen keeps misting up. At first I horrific thoughts of head gaskets or holes in the heater matrix etc, but now I've read your section on FAQs about draining the scuttle thingy I'll have a go at that first, Can someone tell me if I'm on the right track?
Secondly, I was fooled into thinking that the car had cruise control, because of all the buttons on the steering wheel. But I have heard you can retro fit them. I'm a bit of a ar%^ with electrical things and I'd like to know if there is anyone near Manchester that can do them?
Thirdly, is there any way you can turn off the trip computer. I find it a PITA
Thats all for now.
Good site everyone
Chris
Darwen Lancashire
Hi and welcome :)
As far as the misting up goes, there are two things you should do. Firstly, clean out the scuttle drain following the guide on here in the maintenance section (let us know if you can't find it). Secondly, replace your cabin filter, which is located juet below the windscreen on the passenger side, under the bonnet. This should cure it. Driving with cilmate in "Eco" mode (if you have that on yours) will cause misting at this time of year also.
When doing the timing belt change, I must stress, you need to change the whole timing belt KIT, which includes new tensioner, new guide pulleys and new bolts. It's the tensioner that fails before the belt, which causes the timing to slip and bend valves at best. Needs to be done every 40k miles, and needs to be done now if you've no solid documented proof of the last change. Changing just the belt and not the kit is crazy.
Use Genuine Vauxhall engine oil is my advice, others may vary.
Fitting cruise on yours is a peice of cake. All you need is the stalk, which is a 5 minute job to fit, and to make sure you have the correct pedal switch, (the one Tunnie described in your welcome post). If this is the case, then the only other thing you need to do, is get cruise enabled if it is not already. You need someone who has a Tech2 for this, Only Vauxhall dealers will really have it, but if you're nearby then TheBoy offers a very reasonably priced tech2 service.
As far as turning off the fuel computer etc, I'm not aware of a way to turn it off. You could do something really crude like unplug it, but I would strongly advise against. The computer is a little gem for alerting you to problems before they become serious, such as oil level, coolant level, brake pads, even washer fluids and lights not working.
Hope this helps, Enjoy the Omega, they are a great car.
Just set the computer so it diplays outside temp....
Or pull the backlight bulbs id the thing really annoys you....
Chris
Darwen Lancashire
I'm in Bury if you want to borrow a cam locking kit if you want to change your own cam belt and tensioners.
I've done the Timing Belt...well, I've had it done and I don't expect any trouble from that.
As far as the misting up is concerned I did the scuttle this morning and even for a thumbless twit like me it was an easy job It worked best when I poured a kettle full of hot water down the pipe!! It was dirty, but not blocked
I will get my cruise control sorted asap but I have another, probably really dumb question, what's a Tech2?
The diagnostic computer as used by dealers...
