Omega Help Area => Omega General Help => Topic started by: omegaman1997 on 10 February 2007, 20:20:36
Title: No hot air (climate control)
Post by: omegaman1997 on 10 February 2007, 20:20:36
Hi everyone im back to pick your brains!!!!!!!!
ok well ive had this prob for a while first the compressor bearing went so i got a new one sorted cold air nice but not in this weather  :'( so i checked the pipes to the heater matrix top one hot bottom one was cold so i have replaced the bypass valve good i thought this will get it sorted but no still no hot air the top pipe is now really hot but the bottom pipe is still cold  >:( i know that it is vacum operated do you think there could be a split somewhere on the pipe or could it be something else please help getting really cold a frustrated now lol
Regaurds
Paul
Title: Re: No hot air (climate control)
Post by: TheBoy on 10 February 2007, 22:20:50
Regaurds
Paul
my initial thought is blocked matrix, or airlock in it...  ...can you flush matrix with hose?
Post by: Marks DTM Calib on 11 February 2007, 14:19:40
Bypass valve is vac operated so if there is vaccum leak then you get no warm water flowing through the matrix....
So, as always....check the engine bay vac pipes first....
Post by: omegaman1997 on 11 February 2007, 15:31:00
hi thanks for getting back to me i will try to flush it and see what happens i have just looked at the old bypass valve and the top pipe which has always been hot you can see that water has been flowing through it fine but the bottom pipe is clean i think the car has had this prob for some time also if you suck the top of the valve it does work so i think it is definatly a vacum prob but i have checked the pipes around and they look ok but where do the vacum pipes go after they have come through the bulkhead they seem to go back through again near the gearbox is this right and where do they go after that?
thanks guys :y
Post by: Marks DTM Calib on 11 February 2007, 16:19:33
Have a look in the maintenance guides here for info on the vac pipe routing...
V6 Vac pipe info (http://www.omegaowners.com/forum/YaBB.pl?num=1152565204)
Both the feed and return vac pipe sould pass through the bulk head by the heater matrix pipes... (right hand connection is to the bypass valve, left hand one is te vac feed to the cabin controls).
Does it have climate or dial controls?
Post by: omegaman1997 on 11 February 2007, 17:11:45
it has climate control i have just been down to have a look and there doesnt seem to be any vacum there to move the valve any sergestions ???
Post by: Taxi_Driver on 11 February 2007, 18:22:01
Does it blow hot if you set the climate to HI?
Post by: omegaman1997 on 11 February 2007, 19:10:30
no it just blows cold constantly
Post by: Taxi_Driver on 11 February 2007, 19:23:53
Thats blown my theory away then.....sorry dont know then  :-[
Post by: omegaman1997 on 11 February 2007, 19:39:47
np thanks anyway :y
Post by: Markjay on 12 February 2007, 00:11:44
From memory (too late to go out and check now..), the 'nothing happens when engine is cold' only occurs in Auto mode, if you crank-up the fan manually it starts blowing - albeit cold air....
Post by: Marks DTM Calib on 12 February 2007, 08:05:49
You need to get those vac pipes checked .......
Post by: SteveD on 12 February 2007, 22:05:42
The vac pipes go to two solenoids on the passenger side of the heater box. If you pull the glovebox out you can see them. One screw holds them on. It's easy to drop them down and join the vac pipes together to confirm your HBV is working. One of the solenoids is for the HBV, the other is for the variable fan speed.
