Omega Help Area => Omega General Help => Topic started by: ClarCE on 27 February 2007, 13:31:52
Title: V6 Breather System Photos
Post by: ClarCE on 27 February 2007, 13:31:52
Hi all,
I don't suppose anyones got any of the photos from the V6 breather system cleaning guide saved?  They don't appear when I look at it...
Cheers,
Chris.
Title: Re: V6 Breather System Photos
Post by: Gaffers on 27 February 2007, 13:46:46
I will be taking off the plenum and rocker covers this weekend.  I will have them posted by mid next week.
If you can hold out till then bud...??    :y
Post by: ClarCE on 27 February 2007, 14:08:59
Might be able too ;)
Noticed your only up the road from me - theres a few of us omega types down this way :)
Post by: Gaffers on 27 February 2007, 16:43:38
Certainly is, we should have some of those sad stickers done so when we pass each other on the A303 we can hang out the window and hi-5 ........ ok maybe not.....   :-/
Post by: r.welfare on 27 February 2007, 22:47:48
Looks like we might have a local subsection going  ;D
Looking forward to these photos mrgaffney, I will be cleaning out my breathers shortly...
Would be interested to know how to get the EGR valve nut (the big one!) undone, as I couldn't when I changed my cambelt and ended up disconnecting the inlet manifold from the plenum.
Post by: JamesV6CDX on 27 February 2007, 23:51:42
Chris, I'll do your breather system at the same time as the cam cover gasket change (necessary to stop gaskets blowing again).. you can see how it's done and take pics...
Post by: ClarCE on 28 February 2007, 00:02:15
Hi James, that would be ace, then when I need to do it again I'll be sorted, and of course I'll post them on here :)
Post by: ians on 28 February 2007, 21:02:21
r.welfare,
I'll sign up for the Newbury section too (I'm in Woolhampton).
I used a big adjustable to release the EGR pipe.
Cheers
Ian
Post by: r.welfare on 28 February 2007, 22:48:53
Thanks Ian, I tried that last time - I guess mine isn't up to the job, I'll borrow one from my neighbour  ;D
Post by: Gaffers on 01 March 2007, 07:37:38
r.welfare,
Cheers
Ian
often helps if you tap the wrench/spanner you are using.  Not too hard just enugh to send vibrations through the joint and release those stubborn ones.
Post by: sir moanalot on 01 March 2007, 16:34:48
blooming heck, just seen your from tidworth ! that brings back memories for me -when i wore green and bossed people about!!!! tone.
Post by: Gaffers on 01 March 2007, 16:38:59
Thats what I thought I would be doing, now its all pink and fluffy..... long tone.......
