Omega Help Area => Omega General Help => Topic started by: jakeyboy2506 on 04 March 2007, 20:02:17
Can anyone please tell me how to remove the air con switch and replace the bulb on my 1997 V6 Reflection
Thanks in advance :)
It just pulls out. careful not to damage adjacent ones. Use a pair of butterknives...
Jaime your just too posh, I haven't got one butter knife let alone two ;D
Nor have I, but it gives you an idea of what you are looking for...
so thats how to remove the switch sorted..... ;D
as to changing the bulb,its not a bulb,its 2 leds soldered into a peice of plastic.
cant ,just change the bulb :'(
unless ur doing the whole change the colour of my dash thing.get a new/secondhan switch.
If I recall correctly, the switches aren't too pricey - even at the Stealers 8-)
Iirc i was quoted about £17 + vat for a eco switch from a stealers.
They should be bulbs....unless they have been changed for LED's......
ok there bulbs :-[, but there soldered on to a plastic thing
can you change them ????????? ;D
If you can use a soldering iron then yes.....
