Omega Help Area => Omega General Help => Topic started by: chris b on 08 March 2007, 22:13:21
Title: help!!!! coolant light.
Post by: chris b on 08 March 2007, 22:13:21
help chaps!! this dam cars driving me mad. am geting coolant cheek up on my screen but the coolant tank hasent lost eny coolant? it`s still on the max level. the car runs at norm at 95 as it alwas has and fan cums in at 97. it`s got no leaks and heater is still nice and worm . can eny one help be for i go mad ? >:(
Title: Re: help!!!! coolant light.
Post by: Andy B on 08 March 2007, 22:17:35
The switch on the float in the header tank isn't making. You could try a good soak in caustic but the ulitmate fix is a new header tank - about £30. Ideal cahnce to change the coolant for pink antifreeze. Or .... you could just bridge the connection underneath the tank - that'll get rid of the message! ::)
Post by: chris b on 08 March 2007, 22:22:45
thank my friend al have a go at cleaning it but it is a bit shit up in there so a new one mite be a beter way.  :y
Post by: Taxi_Driver on 08 March 2007, 22:28:05
When its cold....try giving the float in the header tank a prod to make sure its not stuck....other than that check the wiring underneath it for corrosion....if its not that either than as said you need another header tank....around £40ish iirc or short the wires together underneath the tank and the mid willl stop complaining  :y
