Omega Help Area => Omega General Help => Topic started by: Skint on 11 March 2007, 12:12:25
Title: Help needed to identify disc part number
Post by: Skint on 11 March 2007, 12:12:25
Hi all
My poor car failed its MOT big style, mainly on brakes.
I picked up some discs from EuroCarParts, they had identified them using my car registration number. Unfortunately when I came to fit them on Saturday afternoon I discovered that the offset on the discs they had supplied was too small, can be clearly seen when they are side by side. I have been unable to find any markings on the fitted discs.
I have a 1995 Omega 2.0 16v
The discs fitted are the same diameter as the supplied discs but with an internal offset of approx 50mm.
The discs I was supplied have an offset of approximately 34mm and a Part Number of 104720150 and tridex No 9588910
markings on the supplied wrong disc
125-119 (oz) 73 46.05 MIN.TH.22.0mm
Info from the Box
425119
24.0125-0119.1
288*25,0*22,0
vent
applicable to 569056
Vectra B 1,6 + 16V/11,8 + 16V/2.0 DI + DTI + 16v ab Ch.-Nr X1000001
2,0 16V/2,5 V6
Any assistance gratefully received.
Regards
Sandy
Title: Re: Help needed to identify disc part number
Post by: ChrisMV6 on 11 March 2007, 12:23:04
Are these front or rear discs?
The front Discs and Pads are the same on all models from late 94 to 2002 but the early 94 models definitatly had different pads so the discs may be different aswel, i could check for you tomoz if you like when i'm back at work (I work at a Motor Factors)
Post by: Skint on 11 March 2007, 12:59:50
They are the front discs. I am lead to believe there are 2 diameter differences but I think from my internet searching that these are between the larger engine cars and the smaller ones.
I have found 2 different widths as well as apparently 2 different diameters.
Regards
Sandy
Post by: TheBoy on 11 March 2007, 14:46:26
There are only 2 different types fitted to Omegas - pre 97 2.0l ones (286mm) and post 97 2.0l and all other models (296mm).
I would be wary of fitting pattern parts, the ones on mine are utter rubbish.  If you know anyone with a Trade Club Card, genuine ones are around £70 + VAT for the disc and pad set.
Post by: Markjay on 11 March 2007, 18:04:41
...you say in your email that the disks you were supplied are for Vectra, not Omega? If so no wonder they don't fit... but either way, do as TheBoy suggested and get original Vx disks&pads.
Post by: Markjay on 11 March 2007, 18:11:13
Also, after some more googling it seems that 569056 is one of GM's own P/Ns for the Vectra disks, and that if you wanted to get Omega disks using the same numbering system (which is not a very common one) then you should be asking for disks which are:
P/N 569053 - 286x24
  or
P/N 569044 - 296x28
Post by: Dave-C on 11 March 2007, 20:52:52
Sounds to me as though they've supplied for Omega A and NOT Omega B..
DC
Post by: Taxi_Driver on 11 March 2007, 21:52:59
Eurocarparts aint that brilliant at getting parts correct on the reg number.....i know
Im only just up the road.....actually i was in Bristol today...did it in 35 mins...and that wasnt going mad on the m4....if you need correct parts give me a shout....be willing to get em with my TC card  :y
