Omega Help Area => Omega General Help => Topic started by: JamesV6CDX on 21 March 2007, 14:32:27
Title: 3.0 thermostat
Post by: JamesV6CDX on 21 March 2007, 14:32:27
When I rebuild the Elite I want a new stat
I've heard that there is something you can do, in order to use the 2.0 stat? Mark, you mentioned it once.
Any ideas how this is done, and if it's OK to do?
Title: Re: 3.0 thermostat
Post by: Marks DTM Calib on 21 March 2007, 14:56:55
If the housing is ok.......you can fit a repalcement bayonet insert...these are the same across most 95 onwards vaux engines (i.e. 2.0)
Post by: JamesV6CDX on 21 March 2007, 15:08:24
Cool, I will steal the new 2.0 insert then!
Just twist and fit?
Post by: JamesV6CDX on 21 March 2007, 15:08:58
Can you still test the stats in a saucepan of boiling water?
Post by: Marks DTM Calib on 21 March 2007, 15:17:03
Yes, you can still test them in boiling water.....
The fitting is a bayonet style setup so you press the retaining plate in and rotate it to release it....dead obvious when you look at one....
