Omega Help Area => Omega General Help => Topic started by: JamesV6CDX on 25 March 2007, 11:00:37
Title: Shall I replace oil cooler...
Post by: JamesV6CDX on 25 March 2007, 11:00:37
When doing my HGs? Just as a precautionary measure?
I can't really afford to... but wondered if I should....
Title: Re: Shall I replace oil cooler...
Post by: TheBoy on 25 March 2007, 11:03:10
If no signs of oil in water, no. Its an extra £90 quid.  Can be 'easily' changed later if reqd (ie without taking heads off)
Post by: JamesV6CDX on 25 March 2007, 11:05:10
What about re-sealing the plate?
Post by: TheBoy on 25 March 2007, 11:09:32
Not sure - can damage the cooler bolts....
Personally, I would leave if OK, unless someone advises otherwise...
Post by: JamesV6CDX on 25 March 2007, 11:11:04
My feeling too... I'm just thinking back to what you said, that the cooler could be causing the pressurising?
There are also several crusty deposits in the valley  :-/
Post by: Marks DTM Calib on 25 March 2007, 11:51:37
With the heads off, you can remove the plate with the cooler still attached and hence you dont risk damaging the fine thread....
Hence re-sealing the plate is pretty easy.....do watch the oil cooler pipe connections to the block....spray with penetrating fluid for a day or so before attempting removal..
Post by: JamesV6CDX on 25 March 2007, 11:58:00
Presume to seal the plate, I still need to remove (disconnect)  the oil pipes completely... from cooler and block?
I don't think I have the special tool to get at them :(
Although, with the heads off, maybe access will be easier to reach down.....
Post by: Marks DTM Calib on 25 March 2007, 11:59:07
Yes, easier to reach from above....a 19mm crows foot spanner is the weapon of choice...
