Omega Help Area => Omega General Help => Topic started by: Gaffers on 25 March 2007, 14:55:45
Hi there,
I am looking at renewing my gearbox oil but I cannot fathom which one I need off the Opie website.
I have a 2.5 petrol auto
VMT
Gaffers
Hi there,
VMT
Gaffers
Must be Dexron III
Sure, but I heard that Opie did 5L for #25 ish quid yet I cannot for the life of me find it, just the 1L for 7.99...... yurk!!
Most places do. My local factors near work do Coma 5l Dexron III for £22 retail (and they give trade if you show TC card ;))
The ATF recommended by Mark DTM iirc:
http://www.opieoils.co.uk/performance_lubricants/fuchs.aspx
Fuchs Titan ATF 4000 (Dexron III) 5L £29.99
Fuchs is top-notch German brand used as OE by German car manufacturers.
Better explained on one word - used to use it in bikes
Silkolene.
Now why call your self Fuchs when Silkoline was such a strong brand
Having had an engine on my motorbike rebuilt my Mistral Engineering (a proven engine builders) they advised me to stay well clear of Silkolene....they said if foams too much.
l was told kendall Oil is the best you can get but hard to find in the UK
Castrol gets my money 99% of the time
Oil thread.... I'm going to just sit back and enjoy this one... 8-) keep them coming! ;D
I just bought a 5 litre container of this stuff:
(http://www.commaoil.com/Product%20%20Shots/Oils%20&%20Lubricants/AQ3.gif)
- £15.99 inc. VAT from Halfrauds with trade card :)
soooooooo ... what else do I need to buy, I'll be sourcing the parts and getting a local garage to fit it as I don't have a suitable lift or ramps ...
I'm thinking along the lines of:
P/N 96014235 - large sump gasket
P/N 96014234 - small sump gasket
P/N 96015432 - filter assembly
... is there anything else needed? ta :y
How much was the dextron III without the TC?
I've heard that when replacing the gearbox sump you just need some gasket maker compound which works better than a new gasket, but I cant remember which one...
retail price is £20.99 (from Halfrauds) ... not sure about the gasket maker, I've heard of it being used on the engine sump but not the gearbox ones ...
The Vx gasket set is only around £13 Trade, but Marks DTM says that the gaskets are no good, better to use Loctite liquid gasket instead.
The filter is quite expensive - circa £60 - and if it is not broken then it can be cleaned.
You will also need the drain plug washer - p/n 11023582 (13 Pence...)
OK, thanks for that - is there a Vx P/N for the loctite instant gasket or will the garage need to source it? ta :y
