Omega Help Area => Omega General Help => Topic started by: JamesV6CDX on 31 March 2007, 14:39:19
Title: Urgent torque setting needed
Post by: JamesV6CDX on 31 March 2007, 14:39:19
V6, head to block, sequence and torque / angles needed... on my way there as soon as I find out!!!
Title: Re: Urgent torque setting needed
Post by: JamesV6CDX on 31 March 2007, 14:57:27
Is Anyone with Haynes online?
Post by: Markie on 31 March 2007, 15:02:56
give me two minutes till i fetch mine.. :y
Post by: JamesV6CDX on 31 March 2007, 15:05:28
Good man :)
Post by: Markie on 31 March 2007, 15:07:12
cylinder head bolts i take it?
Post by: JamesV6CDX on 31 March 2007, 15:08:12
Please....
Post by: Marks DTM Calib on 31 March 2007, 15:11:18
25Nm +90 deg +90 deg +90 deg + 15deg.....  (the 15deg is optional....)
Bring it down in stages (i.e. all to 25Nm then all plus 1 90 deg etc) working from inner bolts to outer.....
use lots of grease on the top and bottom side of the head bolt washer......and a very light oil on the threads.....not much though, you dont want them to hydraulic....
Post by: Markie on 31 March 2007, 15:11:22
quoted......haynes
cylinder head bolts 25nm / 18 lbf ft stage 1
angle tighten a further 90degrees stage 2
angle tighten a further 90degrees stage 3
angle tighten a further 90 degrees stage 4
angle tghten a frther 15 degrees stage 5
let me see if i can find sequence  :y
Post by: Marks DTM Calib on 31 March 2007, 15:13:55
6 1 3 7
o o o o
o o o o
8 4 2 5
Post by: Marks DTM Calib on 31 March 2007, 15:14:48
As a tip.....put a piece of kitchen roll in each bolt hole before starting each stage of tightening.......remove it as you tighten the bolt....that way you wont miss one.......then place them all back in again before the next stage....
Post by: Markie on 31 March 2007, 15:21:10
o o o o
o o o o
8 4 2 5
jeez the mans like lightening   :y ;D
Post by: Marks DTM Calib on 31 March 2007, 15:26:11
I dont have to look it up.......
Post by: Markie on 31 March 2007, 15:58:53
i knew that  :y
Post by: ians on 31 March 2007, 17:38:12
sad use of brain cells..
and won't that kitten roll get fur everywhere? ;D ;D
