Omega Help Area => Omega General Help => Topic started by: TheBoy on 03 April 2007, 11:05:55
Title: 2.5TD aux tensioner
Post by: TheBoy on 03 April 2007, 11:05:55
Whats the proper way to release tension to remove belt?  Is it a case of an allen key in the tensioner and turn (in same way as petrol with 15mm spanner)?  If so, what size allen key?
Title: Re: 2.5TD aux tensioner
Post by: Auto Addict on 03 April 2007, 18:12:29
It's got to be, from what I saw of it.
Post by: Omegatoy on 03 April 2007, 20:02:44
have done 2 and both times put a heel bar in the bracket and using slow firm pressure it eased back to allow the belt to be removed, as its hydraulic youcant just shove it and hope has to be firm steady pressure and it will slowly give,   also did it this way when i had to replace the shockabsorber on the tensioner!!
Omegatoy
Post by: TheBoy on 03 April 2007, 20:05:15
Omegatoy
What is a heel bar?  :-[
Post by: Omegatoy on 03 April 2007, 20:21:05
Blimey how do i describe one of them? its a bar with a heel on it like an upside down T with a bit missing :o oh never mind i have a tool here that will do the job as i used it on the green one your welcome to borrow it!!
Post by: TheBoy on 03 April 2007, 20:22:58
Next time I see you, show it me, I will probably know exactly what you mean...! :y
