Omega Help Area => Omega General Help => Topic started by: Martin_1962 on 05 April 2007, 09:20:28
Title: Engine number location V6
Post by: Martin_1962 on 05 April 2007, 09:20:28
AutoVaux need it for my thermostat.
Any ideas where it is?
Title: Re: Engine number location V6
Post by: Bo Bo on 05 April 2007, 09:25:34
Is it on your V5 doc?
Post by: Marks DTM Calib on 05 April 2007, 09:30:07
You are joking......there has only ever been one type of stat fitted!
I am fast hating this company.......
The engine number is stamped onto the block-bell housing flange near the crank sensor....
VSC on ebay also do them......if they are supplying the newer style part you need new longer bolts...
Post by: Marks DTM Calib on 05 April 2007, 09:50:21
Heres one.....
http://cgi.ebay.co.uk/Vauxhall-Thermostat-Assy-Calibra-Cavalier-Vectra-Omega_W0QQitemZ200094371944QQcategoryZ10404QQrdZ1QQcmdZViewItem
Looks like the later design to as it has the improved seal on it....
Post by: Matchless on 05 April 2007, 10:00:05
If the later part with the thicker flange was used right at the end of production and they have both the old (superceeded) part and the new part in stock then they will ask for engine numbers.
You want the new part with new (longer) bolts, the early ones had a very thin flange and tend to crack, the later part is much thicker around the base and has an improved seal.
Post by: Martin_1962 on 05 April 2007, 10:19:58
I've bought the Ebay one - a bit cheaper than AutoVaux
Post by: Marks DTM Calib on 05 April 2007, 12:27:28
No....old part is no longer serviced and there was never a specified engine cut over for them....in fact, I dont think the modified one was ever fitted during production....
Anyway, you dont want the old version because the seal is rubbish....
Post by: ClarCE on 05 April 2007, 13:26:45
Anyone got a part number for the bolts? And how many?  I didn't realise this when I bought my new stat..
Post by: jonny2112 on 05 April 2007, 23:13:46
Just by the by, the engine number is stamped adjacent to the oil filter. At least it is on the pre facelift.  :)
