Omega Help Area => Omega General Help => Topic started by: JamesV6CDX on 13 April 2007, 07:24:02
Last night, when it was quiet, I thought I'd fire up the Elite, and just run it along my private dual carraigeway, to make sure everything was OK before the MOT on Thursday.
Fired it up - fine. Foot on brake, Gear in D. Off brake, onto throttle. Hmm.. not going far.. put foot harder on throttle... a bit faster, but not by much.
Stop, put gear in "1". Pull away again - whooosh.... like a rocket.
So it's looking like a gearbox issue! This is probably confirmed by the fact that When I press sport mode, nothing happens - no lights. Kickdown is not working, and neither is Winter mode.
It's like it's in severe limp mode... but no messages on MID.
One thing that did cross my mind.. I did knock the O2 sensor off on the passenger side when fitting the cats back on.. I wondered if it wasn't fully home..however I would get an EML?
Engine is fine.. revs very high.. but something's up with the box.
It must be electrical, it can't have developed a mechanical fault sat on the drive!!
Balls!!! Any advice?
May be wide of the mark, but transmission fail mode reverts to manual control, D is 4th, 3 is 3rd... 1 is 1st.
Was it starting off in 4th gear? You could try running up 1,2,3 to see if it changes on the move?
I tried that.. and yes.. it does change through the gears if I do it manually :-/
Do you have any lights at all on the selector array?
Sounds like its in limp mode......is the cam/crank plugged back in ok....altho i would suspect it would be difficult to start as well if at all.
If it is in limp mode....it should be recording a fault code....anything showing with the paperclip test?
Since sorting the immobiliser prob, the EML has gone off. Only fault codes, are knock sensor, and EML low voltage (no longer present)
Selector lights are fine...
Gearbox ECU connnected properly?
Rev counter working properly?
Rev counter is fine...
I don't even know where the ECU lives...
Throttle pot ok.....
How do I check?Would that account for no sport mode and limp symptoms?
Its not unknown....normaly flags an engine fault though....whats the battery charge voltage to...
When running, measures just under 14v
Is there anything I can check, or look for? It sounds almost I've knocked something off but I don't know what :(
Sorry to hear you're having probs James :( It was all going too well!
How about the connector on the side of the gearbox, any chance you're knocked that off? Or dislodged?
Or the selector switch connection......
Get underneath and confirm the simple stuff is all ok i.e. connectors etc....also check the large multiway connectors near the battery to make sure they are all well secured...
Will do mate, I'll do it all after work at 4.
I'd appreciate as much advice as possible from anyone with any ideas, about what to check, exactly where to check it and where it is :)
Balls... it was going to well... the engine sounds like a beast though.. really nice.. so I hope this can be resolved :(
No fuses blown? I notice my auto box fuse is different to all the others, suggesting it has blown in the past.
Sounds like the gearbox ECU isn't controlling the gearbox for some reason and the lack of warnings makes me think it's something simple like no power or a connector off somewhere.
That was our thoughts Kevin... Where abouts is the gearbox fuse (s) ?
I could have sworn there was a Howto from Mark on here with the fuse numbers but I can't find it today. It's one of the fuses in the main fusebox in the driver's footwell, a 10 amp one, middle row towards the left hand side IIRC, but have a general look for blown fuses, loose relays and connectors both there and in the underbonnet fuse box.
Going to have a look at this, at 4pm
Can anyone tell me where the Gbox ECU and connector is, and the fuse.. and anything else to look for....
Gearbox ECU is behind the drivers side dash mounted on the A pillar.....
Gearbox plug is on the passenger side of the gearbox.....
Gearbox fuse is here:
http://www.omegaowners.com/forum/YaBB.pl?num=1161602008
Its fuse 9.....
AFAIK the ECU should be behind the right hand Fascia panel " Damn Mark beat me to it "
check winter mode switch as well.... mine did something similar (but not i think , exactly the same) , and it turned out to be the switch being seized/jammed
check fluid levels and cooler connections??
If the car will get here, I can stick it on Tech2. That will show what the ECU thinks is wrong (though not necessarily what is wrong). Is MID right one for car, if it came from manual, no g/box warnings will appear.
