Omega Help Area => Omega General Help => Topic started by: RXC on 14 April 2007, 10:23:16
Title: Sun roof problem on 2.6 CDX
Post by: RXC on 14 April 2007, 10:23:16
My sun roof on my 2002 2.6 CDX opens on its own.  Reset as advised by the handbook but to no avail. Does not open fully, just goes into firstt tilt.  Any ideas.  Thanks
Title: Re: Sun roof problem on 2.6 CDX
Post by: TheBoy on 14 April 2007, 10:25:21
Does it open properly when doing reset procedure?
Post by: Markjay on 14 April 2007, 10:29:23
Try:
http://www.omegaowners.com/forum/YaBB.pl?num=1152602030
Then:
http://www.omegaowners.com/forum/YaBB.pl?num=1174930513/14#14
(thanks sounds2k!)
Post by: RXC on 14 April 2007, 10:31:09
Yes, works perfectly well, and then the problem is solved for a while, and then starts again
Post by: TheBoy on 14 April 2007, 10:38:24
Needs a bit of lub then ;)
Post by: sounds2k on 14 April 2007, 10:48:46
... sounds very much like mine did, the motor sounded quite laboured when operating. In fact when I stripped the gearbox, there is a metal cog which is the part that pokes out of the hole in the gearbox case and drives the belt of the sunroof mechanism. You couldn't even turn that by hand - no wonder the motor was struggling! All greased up and that part can be turned by hand OK now, roof opens and closes fine since then ...
