Omega Help Area => Omega General Help => Topic started by: chris b on 15 April 2007, 17:48:58
hi there chaps. can eny one tell me what sort of diff oil i need? vx or other. the car is a 3.0 elite auto 1997 and 150000 miles? think mines shot it? :y
Check out this maintenance guide....
http://www.omegaowners.com/forum/YaBB.pl?num=1161520937
All the info you need......basicaly its a good quality 90 grade hypoid
cheers m8 took your info in it is worse when pulling away round a bend? it`s not ex plod it just get driven hard.
Its worse when on a bend....in which cae it might be an LSD......I would use the BOA90LS....if its not an LSD it wont cause any damage.......if it is it will make all the difference.
cheers marks dtm. have got the right oil and the lsd additive 2day doing it wendsday night also got your step by step guyd 2 do the job right. do i realy need 2 take the diff cover off? or do i just drane the oil out by slacken the bottom 3 bolts? will all of this sharpin pull off speed as it dose tend 2 bog down sum times. :-/
