Omega Help Area => Omega General Help => Topic started by: jonny2112 on 18 April 2007, 21:09:59
Can someone give me a bit more information on this task, as part of changing the cam cover gaskets, please?
Thanks a lot
Thanks a lot
Blooming great multiplug behind the injector/inlet....
Thanks a lot
*** EDIT: Wrong picture removed :-[ ****
Looks more like multiram?
Err, yes, there is a plug at the far end of the injectors rail.... can't bee seen in the pic though:
(http://img103.imageshack.us/img103/563/image053lg3.jpg) (http://imageshack.us)
Its a large connector - you can't miss it during stripdown, and it simple unclips. Nothing to worry about really :)
Undo the torx bolts holding the inlet manifold in place, slide the manifold towards you and you will see the multiplug. Undo and then tip the manifold over to the right so you can remove. WATCH OUT FOR THE BOLTS FALLING INTO THE INLETS!
I left mine connected!
