Omega Help Area => Omega General Help => Topic started by: Taxi_Driver on 04 May 2007, 06:24:52
Hi,
I have a 2.5v6 Saloon , manual.
Want to have an lpg conversion. The questions i have got are:
1: Does LPG make you lose a bit of power? (been told that)
2: If so can i flip between lpg and normal petrol?
3: If so will i regain the performance when on normal fuel?
4: How much do they cost roughly?
Regards
Matt
1 Yes
2 Yes
3 Yes
4 V6....around 2k if you pay someone to do it
Hi,
Regards
Matt
Yes about 10bhp - but this can be got back
Yes
Yes but can you afford to
Depends who does it
How can the 10bhp be got back?
If that is right then i would consider ripping out the normal fuel tank , lines and everything else and just run on lpg
Would i get a reduction in road tax if it was just an lpg car too?
Matt
LPG systems piggy back on the petrol system unless you want to replace the electrical system
Also what happens if you run out of gas?
V6 - 800 notes DIY.
As Martin says abov - LPG can't really run without starting on petrol. Even if it could it'd cost sihit loads to replace existing ECU/Looms and the rest of the gubbins that make the car run on petrol! Too much of a pain in the a*see in my book. It's best to let the GM ECU control the injectors and emissions.
