Omega Help Area => Omega General Help => Topic started by: amba on 04 May 2007, 13:11:50
Title: Fault code 22
Post by: amba on 04 May 2007, 13:11:50
After a bit of sweating and swearing have now managed to replace crank shaft sensor..worst bit was treading new cable as they dont allow much spare..anyway job done and car now runs a bit better ....have checked fault codes and still have 22 showing ..throttle sensor...could one have knocked out the other or is this just pure coincidence..anyway rang Vauxhalls and after laughing at the price £73.01 decided to be mean and buy one of flea bay..lets just hope that is better..just wondering if anybody else had had similar associated sensor problems
Title: Re: Fault code 22
Post by: TheBoy on 04 May 2007, 21:40:15
not forgotten to plug throttle sensor back in (on throttle body)?
Post by: amba on 04 May 2007, 22:19:12
no...all plugged in..just a bit erratic still on tick over and when coming to stop  ..revs fluctuate between about 600---1500 just up/down..flash checked and just showing 22 now
Post by: amba on 05 May 2007, 19:38:51
Despite replacing crank shaft sensor car is still running erratic and on any form acceleration other than really gentle eml comes on and gives me fault 22..now I know it is "throttle position sensor"which i am awaiting delivery of a new one..but just want to check:
is it just a straight unscrew/unplug of old one and refit new one
issues with erratic running/rough tickover should be cured with no gearbox warning re-appearing.
has anybody had issues with this sensor before ?
Post by: TheBoy on 05 May 2007, 19:41:56
The is the sensor is returning less that 0.1v, so ecu puts in a substitute value of 30 degrees open...
Do you have a multimeter?
Post by: amba on 05 May 2007, 20:05:54
no multimeter until tuesday..if ecu is putting in substitute voltage is this causing any otherissues which will need replacing or just ne throttle sensor?
Post by: TheBoy on 05 May 2007, 20:38:29
There are some measurements to take to identify why.  If you have a (legal) copy of TIS, its in there.
