Omega Help Area => Omega General Help => Topic started by: Damoblade82 on 09 May 2007, 16:46:27
Title: Crank or Cam
Post by: Damoblade82 on 09 May 2007, 16:46:27
Hello,
Can anybody help. I put my 3.0 omega on a computer and the fault read as engine speed sensor ( present RPM).
Is this the crank or cam sensor as vauxhall was unsure.
Cheers Damo
Title: Re: Crank or Cam
Post by: Marks DTM Calib on 09 May 2007, 17:09:10
First of all....welcome to the forum.
Secondly, what are the fault symptoms...?
Thirdly, what was the code stored, you get a code 31 if the engine is not running....you get a code 19 if the crank sensor is goosed..
Plus, you an read the codes yourself, its very easy...
Post by: Damoblade82 on 09 May 2007, 19:35:54
Hello,
Thankyou for the welcome.
As i am a newbie please forgive me, for being a bit thick.
Did get a code 31, engine was switched off.
Also got a code 129 Exhaust gas recirculation valve position sensor voltage low.
EML was coming on and off. Had codes checked and reset. Now the EML is always on.
Symptoms are sometimes car splutters and holds back.
Post by: TheBoy on 09 May 2007, 20:03:09
Hello,
Ah, the EGR sounds problematic then.
To rule out the 31, do it again with engine running...
Post by: Marks DTM Calib on 09 May 2007, 20:43:10
Yep....EGR valve.....sticking open I would say.....get a second hand part and fit it...
Post by: Damoblade82 on 09 May 2007, 20:51:37
Hello,
I've been told they are expensive new. Does any body have a second hand one for a 3.0L, going cheap!
Cheers Damo
Don't worry got one off Ebay for £30 Cheers.
Post by: Andy B on 09 May 2007, 21:06:36
What about blanking it off? Would that help?
Post by: TheBoy on 09 May 2007, 21:12:51
Sounds like the old valve has stuck, and hence causing a problem electrically and flag ECU to say there is a fault.  Needs to be freed/replaced first before blanking.
Hope that makes sense?
